lachlan
lachlan last won the day on October 23 2022
lachlan had the most liked content!
Location
chch
lachlan's Achievements
Old Boy (5/7)
18
Long story short this is how to get the fault codes from the abs on my jdm v3 sti gc8 Theres a heap of info on the net but none of it was the same as mine Step 1 . Find the 2 earth prongs hidden inside tape in the same tape around where the wires for the green n black diagnostic plugs comes from They are black. And sheathed individually about 3mm round . They are folded back over on them shelves and taped up from factory. Mine had blue tape. Step 2 find this black 2 pin plug that is smaller than the green n black plugs . Jam an earth pin in the blue n white wire . (Nothing happened when i tried the other wire ) Turn key on . Abs light will give you the 10s n 1s for a code . It can only store 3 codes even if you have more Jamming the earth pin in and out at least 3 times clears codes . My only re occurring code was 52 Under the motor on the abs pump where the cam actually drives the 2 plungers was bit rusty / crud . Wd40 n a dung out and some grease on the faces it was good as again The top cover and magnets come off the whole thing with no fuss . The 2x torx 25 you can see . The rotor n brushed n next plate didnt want to come out but that's only because its sealed/glued into the alloy housing . A small tire lever against the rotor broke that glue Codes: Abnormal ABS sensor, open circuit or voltage too high 21 – front right ABS sensor 23 – front left ABS sensor 25 – rear right ABS sensor 27 – rear left ABS sensor Abnormal ABS sensor, abnormal ABS sensor signal 22 – front right ABS sensor 24 – front left ABS sensor 26 – rear right ABS sensor 28 – rear left ABS sensor 29 – any one of four Abnormal solenoid valve circuits in ABS control module and hydraulic unit 31 – Front right inlet valve 32 – Front right outlet valve 33 – Front left inlet valve 34 – Front left outlet valve 35 – Rear right inlet valve 36 – Rear right outlet valve 37 – Rear left inlet valve 38 – Rear left outlet valve 41 – Abnormal ABS control module 42 – Source voltage is abnormal 44 – A combination of AT control abnormal 51 – Abnormal valve relay 52 – Abnormal motor and/or motor relay 54 – Abnormal stop light switch 56 – Abnormal G sensor output voltage Well there was going to be a bonus pic of my car also . Now noone gets any pictures because I cbf making them less than 200kb right now. Where are you lot hosting pictures now ?
Walked past it . But dont remembers it
GC8 Shifter Linkage U-Joint - What options?
lachlan replied to ztikmaen's topic in Impreza, Crosstrek and XV
V3 is staked over rivet . Grind the end off it and punch it out and that will slot right in- 5 replies
- shifter bushing
- shifter
(and 2 more)
Tagged with:
I just bought a vf22 thats in pretty good condition. The factory intercooler needs the top fin in every location ripped off or straightend . Chuck me a message with your email and we can talk more . Im in chch
Steering rack boot deflating too much?
lachlan replied to eZ_Harry's topic in General Vehicle Discussion
The whole point is they are sealed and baloon in and out like bellows .... You need to think less -
Progress is slow. Starting own business Have nearly 20 classic dirt bikes i maintain and race Vq30det jetboat thats fun aswell I have a spare v7 ic someone can have cheap its a bit rough but usable The vf23 can be for sale if someone is hanging out for one . The stock v3 sti intercooler can find a new home if someone wants it I now have a 6s ecu . A ej20k powerfc with controller and a linkg4 plug in . I dont need 3 ecus obviously Still after a whole exhaust. Mine still has a stock down pipe and god knows what else back to a big fart can . Got a red silicon gpi intake hose that someone can have. I want a black one Whos got anything to say about the sub 1000 dollar turbos on trade me ? As far as results and it lasted a a year or it lasted 4 months Or would you rather a high flowed old td05 . Or which version of a tdo5 is the best all rounder on a stock motor. Will get injectors and retune etc Cheers all
Can someone ID cams from numbers /size
lachlan replied to lachlan's topic in General Vehicle Discussion
Well theres a few other threads on the internet matching them as v2 sti ra. With the tophat shim under lifters . Are these cams better / worse than anything else ? And can they go in v3 heads ?- 1 reply
- 1
R3IN 34 MM X 42 MM R3EX 34mm x 42mm And a L set that is the same The lines ground around the label are 1 2 and 3 . 4 is missing . 5 is present . From the front . If 4 was present theyd all be evenly spaced
Was there ever a knock off of the syms headers? They look like these https://images.app.goo.gl/VSB7QCqGvnZjPHDV7 Distinguishing features being slip joints with tie bars . The big pipe loop on the left hand closest side of the photo and the twin up pipes that merge right before turbo . Last owner w**ked on about them but didnt mentiom syms . Last owner also w**ked on about his ranger with a throttle controller being almost as fast as the wrx , among lots of other s*** that fell out when he opened his mouth so didnt pay too much attention
https://linksharing.samsungcloud.com/wHTl09eYErOA Not sure if that works . Lazy mans copy from fb Car has 6s ecu like it should Ecu had stored code for afm and 02 sensor . Where is the done thing place to get a new 02 sensor from ? Even if it needs the plug swapped . Ugly af blue leds for dash dials . Fml Can anyone comment on how to tell between a vf 22 and 23 if the printing is gone off the comp housing ? Without removing it from the car . Probably not Shifter has the usual 8 miles of left to right slop but actually feels nice in and out of every gear . Ugly gay razo pedal covers that don't fit my shoes between them . Day off tomorrow so ill go see what the wof man thinks of it Anyone got a upgraded dump pipe they want to sell . This one appears stock
Thanks fulla
If we pay money can i get rid of the adds on the forum ? Can anyone state at what hp/ boost a vf 22 runs out of inlet or exhaust flow ? Itll do 300 hp and almost 20 psi wont it Not a fan of back pressure Vf22 on a v3 and tdo5 on a legacy rs is my idea of appropriate turbo sizing Will buy a lightening flywheel and metallic clutch if someone has a brand name one lying around thats still got some life
Just bought a v3 sti . Yea the white one that was on fb in chch Had a v3 ra a few years ago . Was 197kw on 11 psi . Electric windows and central locking seem handy now im over 30 ha ha This thing runs ok . Vf 22 . Only on 10 psi so must have retard controller plumbing or its in linp mode . Will figure it out eventually. Desperately needs a new 02 sensor Will panel and paint it at some point and generally just make it as good as it can be . Ive still got an adjustment afm and a wide band so ill turn this thing up till it runs out of injectors . Like to think id build a forged 2.2 but yea have 0 of those bits lying around . Thought i had acess to some v6 heads but apparently not . If someone has some shim under bucket heads they want to sell id be interested Where are you all hosting photos that you share on here these days ?
Who's Online 0 Members, 0 Anonymous, 104 Guests (See full list)
