eKulz
Otago/Southland Member
    Dunedin
eKulz's Achievements
  1. Anyone had a wheel alignment done? Looking for the best price out there. I keep checking deals websites for half price specials but nothing has come up recently. Cheers
  2. I\'ll be up in auckland from the 19th june - 8th july
  3. of course ) not enjoying front wheel drive at the moment
  4. I don\'t have a subaru anymore but I can bring my new Primera haha
  5. eKulz
    SNOWING!
    I don\'t think I\'ve ever regretted crashing my Subaru as much as I do now.. I\'m so sad today would be the perfect day for a drive someone go up mount Cargill and show me some photos
  6. cheers, i\'ll check the readings tomorrow
  7. oh cheers so i\'ll probably be needing a new o2 sensor then?
  8. i\'m getting CEL 21 (coolant temperature sensor), took it out and cleaned all the contacts etc. error code came back up after i reset them within 10minutes. would a new repco coolant temperature sensor fix the problem? also getting CEL 32 (oxygen sensor), i heard there are two on my car so which one is it? i want to clean it up before i spend 200+ on a new one
  9. is this the same as the water temperature sensor? i need to fix mine in my legacy. my fans run whenever the key is in as a \'fail safe\' mode
  10. also - i\'m getting CEL code 32 (oxygen sensor). how do I tell if it\'s the rear or the front one?
  11. Hahahah, "so you signed up for vodafone and they didn\'t want you as a customer, so they signed you up for 2degrees who gave you an 027 telecom phone number"
  12. Just fixed both my rocker cover gaskets.. finally the leak is gone. except there is still the smallest leak now about a 1cm wide drip on the ground overnight? can\'t see any drips actually seeping through the bottom of the gasket like it was before I fixed it. also I wiped the cam covers and the next day theres a really small pool of oil sitting on the top of it.. is it oil or power steering fluid? how the hell did it get up there? im going to redo the passenger side gasket incase it slipped out on the side when I was putting it on, but if it isn\'t that can anyone point me in the right direction?
  13. you sure its not the rocker cover gaskets? lol I just fixed mine they were actually leaking about a 15cm wide puddle every night... which in turn ran down and landed on the exhaust manifold. got so bad when I was going up a hill at less than 50kmph my exhaust set on fire, twice
  14. sneaky sneaky adding posts back! thanks for that mate. will probably go geniune then, that\'s not too bad
  15. sweet how much would genuine cost? accidentally removed my post lol
  • Who's Online   0 Members, 0 Anonymous, 145 Guests (See full list)
