They are a pain i spent over an hour trying to get mine out and still broke it probly best to pop the back out first and then work on the front 2. Try take the air vent out and push from the bottem it might work a bit beter other wise 2 screw drivers either side of the clips worked on the other clip after i broke the orher one
Yea myte try regap them down to that.
Sweet myte hit u up bout them. Have droped it into a mechanic to see if they can diagnois it so will see how they get on.
Yea thaught bout a cracked plug so changed them again nd same thing.
Its not rpm dependint its load if that helps does it as soon as it hits 15psi in all gears
hey guys my 2001 wrx v7 sti has 100k on the clock
has a real bad hesitaion/miss under high boost (15psi up)
have tryed a dif afm
changed plugs 2 times
changed air filter
changed fuel filter
changed fuel pump
changed bov to a gfb one
put an ebc in and still does it
have done snorkelectomy to it but did it b4 i did that and didnt get beter or worse
has a zero sports pipe thingy
runs fine up till 15psi
does have a tuned by HKS sticker on the inside of the gas flap but do they tune factory ecus??? havent had car to long
has factory down pipe with cat in it but zearo sports cat back system
any ideas on what it could be???
has me nd my mates stumped
cheers dvs-b4
mines got 3" from the down pipe back so mid section and rear. his was factory everything. ill let u guys know when iv got my stock standerd version 7 sti which hopefully wont be to long
got the car back 2weeks and 3 days later they didnt replace the diff they took it out and found that the insides where all dry. so they lubed it all up with new stuf and put it back in and now the noise doesnt happen. is it likely to dry up and do the noise again?
yea turbo timers only realy good if u wana run into the dairy to get some milk.
for the boost controler theres is one on trade me one of the st hitech ones for subaru they seem to have a good name
for a bov i used to have a gfb 50/50 plumback witch was good i found it prity quite down low but if u put 10psi through it its loud youldnt use one thats 100% venting or any copy types
with the pody depends what year it is sme need a hole for the air flow meter(2001-2003) other wise u can buy just the adapter from repco.. but u may as well do a snorkelectomy insteed of a poddy
