alfie
alfie last won the day on October 16 2022
alfie had the most liked content!
    2007 BPE outback 3.0R
    2002 WRX wagon
    Christchurch
alfie's Achievements
  1. Just an update. Boon was right. Oil had made its way into the loom plug behind the airbox. No signs of it making it any further. Cleaned it out and the problem is gone. P1507 was caused by the iacv being stuck. Soaked it in CRC and loosened it up. After a running it a few times it appears to have freed up and idle is back to normal after a good run.
  2. Yeah it's AVCS. I'll have a look in the next couple of days and check for oil and have dig around to get to the sensors. Cheers boon.
  3. Hey everyone, I'm after a bit of insight on these engine codes, p1507 - idle control system malfunction and p0365 - camshaft position sensor B (bank 1). I imagine p1507 is due to the engine going into fail safe mode in response to p0365 but correct me if I'm wrong. This is on a JDM 2002 GGA WRX (non STI). Engine starts and idles fine until up to temperature. When it gets to temp and idle speed drops the check engine light comes on and it begins to surge at idle and runs rough if revs are increased from idle. I have found conflicting information regarding the number of camshaft position sensors but as far as I can tell there is likely just one on my engine below the oil filler cap. This one tests at around 2kohm which supposedly suggests it is fine. Is there one below the turbo on non STI models? Is this one visible without removing anything if it is on this model or can I only tell once I get some bits off? I have also found a suggestion that the timing belt could cause this as it can slacken a bit at low revs when worn out. Any help or anything else that you think could be helpful is much appreciated. Cheers
  4. Did it have a big black roofbox on top? I am down there frequently. Its not lowered but the wheels and tyres that its on can make it appear quite a bit lower than standard, especially if just spotted at a glance.
  5. Now looking a little less "middle aged woman" in the fresh shoes
  6. Replaced a fuel injector which had somehow cracked and sprung a leak. Not a big leak but enough to stink up the cabin. Also not technically done to the car........yet. Fresh from powder coat this morning
  7. Were they able to tell if your car was compatible with the upgrade before they hooked into the ECU? Armstrongs in Chch told me that they couldn't tell prior to getting the car and trying it and were going to charge me regardless of the outcome. Needless to say I haven't had it done. I would've thought they could tell me with VIN/engine/transmission numbers.
  8. I experienced this with my BH. After some research I found that they had a reasonably common issue with the fuel lines leaking vapour when in cold temperatures. This was due to the plastic joiners and tees and the like expand and retract at different rates than the hose that they are joining. When very cold this created enough of a gap for a noticeable smell to make its way into the cabin via the heater vents. It wasn't considered a fuel leak as such and it only ever lasted until the engine bay got a bit of warmth in it, so I just let it be. I imagine the only way to fix that would be to replace fuel lines.
  9. I'm pretty sure the JDM facelift OB had self levelling headlights but did not have the self adjusting rear shocks. They were on the North American models though so maybe NZ new would have them. You can tell by looking at the shock and it will have a small can hanging off the side about the size of a 250ml red bull can.
  10. I did this on my old bh5 by disconnecting the return fuel line at the firewall and diverting it into a jerry can. Just let the car idle and you will get a constant flow of petrol from the return line. Took me about 10 minutes to drain 40 odd litres
  11. Thanks, I cleaned the MAF last week, and throttle body clean was next on my list of things to try once I get a chance. I'll try some upper engine cleaner while I'm at it. Thanks for the help so far guys.
  12. It has an aftermarket BOV from when I got it but it is plumbed back. Could the potentially different spring pressure from the factory item cause an issue? I never really gave this much thought as the culprit due to being fully recirculating.
  13. I have a 2002 WRX wagon that has developed a stalling habit. There does not appear to be a pattern to it and no codes are given. Engine is in stock form. It tends to happen at low speeds when slowing down for intersections and slow corners. Occasionally when changing down gears the engine will die while the clutch is disengaged. There are no other symptoms and happens very quietly and smoothly and is not noticeable until either the clutch is engaged and the engine turns over again or if stopped when I try to take off with the car not running haha. It does appear as though the revs drop below idle speed when the clutch is disengaged but most of the time it corrects itself before it stalls. Anyone experienced this or have any ideas on where I should start? Cheers
  14. Mine had some sort of control box tucked in beside the right rear inner guard that all the wires went to. From there it seems to be a single cable running to the front. I didn't bother tracing that because it was more effort than I was willing to give. I just disconnected it at the guard because the box was in an arse of a place.
  • Who's Online   0 Members, 0 Anonymous, 75 Guests (See full list)
