eZ_Harry last won the day on November 14 2020
eZ_Harry had the most liked content!
Drives :
eZ_Harry's Achievements
4 or 5 quarts to change V8 STi Transmission fluid
eZ_Harry replied to eZ_Harry's topic in General Vehicle Discussion
4 Quarts ended up being slightly too much -
Sorry, I should have said "change" transmission fluid. Old stuff out, new stuff in. -
Car: 2002 Version 8 STi 6MTProblem: It can be difficult to shift into first and reverse gear (no other gears are affected). If the car is even slightly rolling, there is no difficulty shifting into first or reverse gear. When I first start driving the car (engine is cold) it is relatively easy to get into gear, but after about 20 minutes of driving it gets much more difficult. At it worst a fair amount of force can be required to shift into gear.Double clutching can help reduce the difficulty. Shifting into first while the car is coming to a stop completely eliminates the problem. If I am at a stop, shifting into second and then straight into first completely eliminates the problem.Attempted Solution: To me this sounds like an issue of the clutch not fully disengaging from the flywheel. I have attempted to fix this by replacing and bleeding the clutch master and the slave cylinder. Unfortunately this doesn't seem to have resolved the issue.Side note, I recently had the engine rebuilt and the mechanic said the clutch looked about half worn, so I opted not to replace it.Could anybody explain potential causes for this problem? I'm confused as to why it only happens in certain circumstances such as from a stop, worse when heated etc.. The only heat sensitive part I could think of is there is still air in the clutch hydraulic system and that is expanding when the car warms... but i just bled the system.
Yeah I've been taking a look at them, not too badly priced. It is more a matter of building the courage to do it, rather than having a do it. I've only done the basics of mechanical work, various gaskets, tie rods, suspension etc. So this seems like it would be quite a big jump... well actually pulling it doesn't seem to bad, rather putting it back in is where I'd expect to get really challenged
UPDATE: I have done a compression test on the engine (It is the first time I have done a compression test and I did it using a new tool, it wasn’t some cheap piece of s*** so I hope the results are accurate) Cylinders: 1: 125psi 2: 0psi (Completely dead, needle didn’t move at all) 3: 135psi 4: 115psi That means that between cylinder 4 and cylinder 1, there is a 16% difference. Just outside the acceptable range. I did this on a cold engine and didn’t squirt any oil in the cylinders. Throttle was wide open. Engine was full of fresh oil, and none was leaking. The most alarming number from the results is that we got ZERO compression in cylinder 2. Initially thought that we hadn’t put the tool in correctly, but we tried a few times and just couldn’t get anything out of it. I find this quite confusing as given what I had discovered previously I figured that it would be a bad piston ring, but that surely wouldn’t be capable of causing ZERO compression. Perhaps there is a broken valve, but how could that have caused enough pressure in the crankcase to spray oil out the dipstick? This is the original post below incase you'd like to read it! HiI recently purchased a JDM Version 8 WRX STi with a supposedly “blown motor”, managed to get it for a really good price and knew it would be a great project which would really stretch my skillset.. win win. I have a fair bit of experience doing general maintenance and mods to cars, but this is a whole different league for me.I didn’t get a very clear description of what happened from the previous owner, what he did tell me was that he was driving the car under boost and then something gave up. He pulled over, and found that there was engine oil sprayed all over the battery side of the engine (not that much made it to the intake side). Lots of white smoke from all the oil and it apparently started to develop a slight ticking sound. He has a video from when it happened, personally I can’t hear any unusual ticking noise, I suspect he may have just been hearing the classic Subaru ticking you get on these engines. It’s been about two weeks since that happened and as of yesterday I have the car sitting in my driveway. I’ve begun the process of diagnosing the issue, here is what I have figured out so far. The engine isn’t seized and turns over well, sounds completely normal when it is cranking IMO. Granted I have only briefly turned it over as I didn’t think it was a good idea to have it cranking with such a small amount of oil left in the engine. Here is a link to a video of it cranking https://photos.google.com/share/AF1QipOXua_4Q3qySSy59KMGdvUa2BkdFkU5YArAsZ2RyCWZB3pT8efwejMTNMQ2vyqF0g/photo/AF1QipNEVVmnjX2GksClrRuIxwCI1BJJG_kyD4DKPwOd?key=OW52QWZydGFxQ2w3MnpaX2NUZ2ZxT0w4c3ZtZDFR I have fully drained the remaining engine oil, there was about 2.5L left. There is no coolant mixed into the oil. I cannot see any glimmering or signs of metal having made it into the oil. Not sure what type of oil was in the car or how long ago it was changed, but it is quite thick and doesn’t smell very good, it kind of has a fishy odour. The coolant system is still full, it seems to be completely intact and has no oil mixed in it. I’ve removed the top mount intercooler, there was a SOLID amount of oil inside this. Not a healthy amount at all, it was enough that it poured out onto the block. This photo just shows the left over in the intake plenum. There is also oil a reasonable amount of oil in the cold side of the turbo (possible turbo seal? But doesn’t explain how all the oil sprayed into the engine bay). No oil found in the air filter. Cannot see any holes or damage in the block Cannot see any damage to piping or lines around the engine (this is really leaving me stumped as to how so much oil made it out of the engine) I think the next step is to run a compression test, hopefully this tells me if something is seriously wrong inside the block.If anybody has any ideas on what is wrong with this engine or suggestions on next steps for diagnosing the problem, then I would greatly appreciate any advice.Cheers!
Version 8 STi oil exploded all over the engine bay?
What could have caused 2 litres of oil to come out the dipstick? -
Steering rack boot deflating too much?
Sure... lengthwise they should move like a bellow. But do you also expect movement width wise? I've read that some steering racks provide air to the boots for exactly this reason -
Hi, Just installed a new steering boot onto a V7 STi. Before re-installing the outer tie rod, I thought I'd check the boot was working properly, so I turned the wheel to full lock both ways. I've noticed that the boot seems to deflate (collapse in on itself) a bit more than I feel comfortable with. At full extension the top part of the boot collapses in with a big dent. Should there be some sort of breather port which prevents this from happening, or is it normal? I feel like it would rip the boot if I left it like that for too long Cheers
eZ_Harry changed their profile photo
I just did a partsouq order and unfortunately in the days following I have rounded and broken some bolts and nuts. I tried calling winger, but they don't have any in stock and as usual the price to import was insane. I'll order from Japan if I have to, but want to avoid it due to shipping time and cost. Car is a 2000 V7 STi I need both of the lower bolts and nuts for one of the front struts, and two new bolts for one of my rear brembo callipers (they both snapped). These are the part numbers 20540AA090, 20540AA100, 901120102, 20550AA010 Does anybody know where I can get ahold of these? Strong for Subaru isn't looking likely at this point, starting to seem like the car might be spending even longer on its stands Cheers
@Loren Well that is a bit embarrassing but clears it up, can 100% confirm for anybody else who comes across this problem, they are not cross compatible.
@Loren @boon I pulled the existing inner tie rod out, visually it matches to the FE, but the thread measured 16mm.. weird. In saying that, I don't really see any reason why either AE or FE wouldn't also fit. The hole on the rack which you screw the ball joint into is just an empty cavity behind it, so if the thread was slightly longer I wouldn't see why that would be a problem. And the longer thread on the side which connects to the outer tie rod wouldn't be a problem either as it would just allow you to make a more drastic change to the alignment. I'm almost tempted to buy the AE just to find out if it fits...
To back that up, according to jp-carparts the rack assembly gear box was changed at the same time as the inner tie rod. So very possibly requires a different thread size https://jp-carparts.com/subaru/partlist.php?maker=subaru&car_baseid=F14003&type=G11&cartype=005&fig_id=347 Can confirm here, search part code 34116
Who's Online 0 Members, 1 Anonymous, 66 Guests (See full list)
