heylinb4nz
    2004 Subaru Legacy GT Spec B (PBMS Tune + Subtech Goodies)
    New Zealand
heylinb4nz's Achievements
  1. I managed to fit in a pair of Jaycar 6.5" Paper Woofers http://www.jaycar.co.nz/Sight-%26-Sound---Home/Hi-Fi-Speakers-%26-Accessories/Component-Speakers/6-5-Paper-Cone-Woofer-Midrange/p/CW2194 but had to use the thick Aepro MDF spacers from Supercheap. http://www.supercheapauto.co.nz/online-store/products/Aerpro-Speaker-Spacers-6-5-.aspx?pid=224801#Recommendations While the door panel was off I also used Dynamat and sealed + deadened the door. basic kit http://abtec.co.nz/Dynamat_Xtreme_Speaker_Kit_10415 or go full hog http://abtec.co.nz/Dynamat_Extreme_2_Door_Pack_10435 Must say the increase in bass\mid was impressive. Had to drill new holes to mount the spacer, and then mount the speaker to that and also dremel away the cowling from the door panel (bit that faces the speaker) to make room. On a scale of 1 being plug and play install and 10 being a pita of a job, I rated it about 8.....so not for people with no car stereo experience. You may get away with throwing a standard shallow set of 4ohm mainstream 6.5" or 6" car speakers in, but the McIntosh amp is designed to have a certain load. Others here may chime in. Should be $100-$150 install job for a car audio place to do it for you.
  2. Im going with stick on performance http://www.aliexpress.com/item/30pcs-STI-Sport-Racing-WRC-tuned-international-3D-Aluminum-Alloy-Badge-Emblem-Sticker-MetalGSTI/32523530168.html?ws_ab_test=searchweb201556_10,searchweb201602_1_10037_10034_10033_507_10032_508_10020_10017_10005_10006_10021_10022_10018_10019,searchweb201603_7&btsid=11d0e7ff-85ac-4503-b487-c15de2d31e66 http://www.aliexpress.com/item/4x-56MM-Car-Styling-Aluminum-STI-Logo-Emblem-Badge-Wheel-Center-Caps-Sticker-For-Subaru/32626195506.html?spm=2114.01010208.3.48.46Ux1n&ws_ab_test=searchweb201556_10,searchweb201602_1_10037_10034_10033_507_10032_508_10020_10017_10005_10006_10021_10022_10018_10019,searchweb201603_7&btsid=3dd57471-bca0-43e6-9903-ea80705f899c http://www.aliexpress.com/item/free-shipping-100pairs-1pair-2pcs-STI-modified-car-EMBLEM-BADGE-STICK-STI-CAR-BODY-STICK/32309823712.html?spm=2114.01010208.3.338.9DEsUH&ws_ab_test=searchweb201556_10,searchweb201602_1_10037_10034_10033_507_10032_508_10020_10017_10005_10006_10021_10022_10018_10019,searchweb201603_7&btsid=ba105fe8-73a9-485f-a9ca-d236e8ba1b90
  3. For the majority of spirited driving at legal speeds on public roads the stock Bilsteins are great. I have little road I drive regularly up to the in-laws house that is used for Targa events and put the BL5 Spec B though its paces many times. Totally acceptable for a road car. Spend money on other things first if you feel you need more cornering ability (sway bars, end links, nolthane etc)
  4. Yeah that's what I thought to, but sure enough it was like $75 for the front and $65 for the rear, + GST. Give Autolign in Hamilton a call. Was about 2 years ago Install was about 45 minutes per side + wheel alignment.
  5. From memory the stock LCA bushings used in the Legacy are oil filled and are usually poked by 60,000 kms, for mine I ended up getting Nolathane replacement from both the front lower front and front lower rear control arm bushings (LCA bushings). Autolign in Hamilton did a good price. $150NZ all up.
  6. It meets Subaru OEM spec (ATF-HP) which is most likely why. Motul is good stuff, so is Penrite, Redline and Amsoil, if it meets the Subaru Spec and you can save some $$$. Id give Winger in Hamilton a call and see if they stock genuine Subaru stuff first.
  7. My PBMS Tuned 2004 Legacy GT Spec B was able to get the following economy (measure by actual litres at fill time from a full tank) Hamilton to Wellington Return - 7.6L per 100 kms Hamilton to Auckland Return - 9L per 100 kms Hamilton to Tauranga Return - 9.5L per 100 kms Town driving - 12-14L per 100 kms
  8. I went for the Subaru stuff, but my understanding is that Castrol make it for Subaru. I personally go for OEM when you're dealing with specialised transmissions, especially if they are being problematic, if you put non OEM in and its still playing up can you be sure that you can rule out the fluid ??
  9. Purchased this recently to fix a seat bolster in my Audi TT that was losing some colour due to friction. http://www.colourlockleathercare.co.nz/product/leather-fresh-repair-kit/ Not much to say really except a) it worked b) it was easy to do It came with liquid leather as well for filling in and laying down cracks, repairing holes and rips etc. had a ball fixing up cat scratches on leather couch, and also a cut in the leather on my other car (now nearly invisible) Highly reccomend this to anyone blessed with a leather interior (or with a couch).
  10. No way, I didnt opt for the 3 hours, just got an alignment only. Funnily enough on Saturday they said 1 hour, and on Monday when I dropped off and decided to go ahead they then said 3 hours...+ extra for the alignment (ie extra over and above the $89 as it would require more alignment changes). Obviously I ddidnt get it raised, but since I had the day off work and was going upto Auckland, I really had no choice but to leave the car to get alignment done. To their credit the alignment did correct a handling issue I was having. But yeah the whole 3 hour quote to raise just the rear 10mm was just a little bit silly and OTT. Dont even get me started on window stickers !!!!! I hate it when they put remind stickers on the front, and even worse when they put advertising stickers on the rear !!!.
  11. Got a mitsubishi colt ralliart ver R, had heat sheild rattle, turned out to be big end bearing, threw a rod 2 weeks and < 300 kms later , 6500 to fix. Turns out car had an oil pump failure previously and owner most likely knew it.
  12. Yeah I get the feeling a few companies would see an Audi sports car and automatically think $$$$...including the dealerships was looking at an Audi A8 recently and got a quote for $370 to do an oil change !!!...dont even get me started on what an RS6 costs to service. I've had bad experiences with naming and shaming , besides most people here are smart enough to know what things should cost and how longs jobs should take, although ive found with european cars it takes a bit more homework.
  13. The latest WRX STI premium is only putting out 225kw, which by the time you factor in drivetrain losses on AWD and Tiptronic you'd be down to the 180 kw atw mark anyway. RE: warranty - Pod filter will void. K&N panel filter should not void as you are not changing the factory intake. K&N filters do not void factory warrenties. - PBMS tune should not void, all you are doing is"tuining" the factory ECU, check with Subaru NZ as they got PBMS to tune some limited edition cars for them. As long as its stock boost all you are doing is "tuning" the car for NZ fuel. - Front pipe, id check with Subaru
  14. I ended up getting just an alignment in the end, and will look at getting a $20 C wrench to do it myself, no jack stands but I can use a couple of 2 ton jacks (with locking) . Main issue is slight rub on bumper mounting tab in upper wheel arch. Thinking I may be able to dremel off 2 mabey 3mm of it to give the needed clearance, but failing that an extra 5mm adjustment may make the room. Would I need an alignment doing 5mm of height ?
  • Who's Online   0 Members, 0 Anonymous, 180 Guests (See full list)
