Super Hobo Man
    2000 Subaru GTB
    Christchurch
Super Hobo Man's Achievements
  1. Yeah bud I've got one in shirley, message me on Facebook Hayden Lambert. Profile pic is me in blue shirt against my bh5 and cover photo is a bl
  2. Hey guys just looking over a mates car and it's throwing code 66 yep worst code, it's so vague and annoying. Basically what are common issues other than your typical Bbod since iv swapped that out already and still has the same problem. It's an auto rev b from memory, symptoms are 0 boost on either turbo and it has virtually no up and go even compared to an NA SOHC, it probably takes a good part of 20secs to get up to 100kmh. Going to test the lines for any vacuum leaks next but if that's not it then I was wondering if there is there any other sensors that typically crap out or what my next move should be? Any help would be much appreciated Cheers
  3. Hey guys! a bit of background, iv been doing a single turbo conversion on my bh5 (its not really your standard single turbo setup though pic below of while it was being built up) followed the guide on the single turbo conversion off of here (bloody awesome by the way) i got it running for a little bit then it shat itself and iv just left it parked up for past couple months out of frustration ahaha. It's also got a g4 sitting in it My car is a sack of S*** basically but i still love it. When I did have it running for a moment and took out for a quick test drive a while back now and on the way back it started to run like S*** then all power would completely cut out except dash lights, it was kind of hit or miss if it'd even turn over (I originally thought ecu might have been preventing it from turning over). Now it will always turn over but never starts. Other issue that's just recently popped up was that if you turn the ignition on then take the key back out the dash lights (cluster and boost controller) are all staying turned on with abs light and engine check light. I'm guessing I've somehow manged to F*** with the wiring somewhere, maybe grounding out somewhere or something? Last part is that the ecu refuses to connect to my laptop, read that could possibly be a fault in the ecu? I realize that I might not get fully accurate information but brainstorming and trying to figure out what my next steps should be which would be a huge help to get my baby back on the road
  4. Hey guys im just wondering how much power a stock ej207 crank can handle? I have been looking at forged rebuild kits and most of them come without crank so was wondering if they can handle a bit more of a bashing compared to rods and pistons.
  5. Oops my bad here you go https://postimg.org/image/hs0z5n8ov/
  6. Once again you are amazing man you really know your stuff. I presume the previous owner of the motor has mixed things up a little since the middle one had the braided turbo return line on it originally. Do you have any idea of what they will have run the biggest pipe to or maybe had an adapter to radiator? Here is a pic of how it was set up before. https://www.flickr.com/photos/thatphotato/21916976024/in/album-72157660371577936/
  7. Hey guys just a nice easy question just need to know where the pipes lead from the top tank on engine presuming the bottom one goes to the metal pipe running under intake, the one just under cap is over flow tank the one next to that is turbo return? and I dont have a clue on the last big one on top of tank is for. Also on the alloy radiator has the one tiny pipe that i'm also unsure of where that runs to. Any help would be much appreciated PS im doing single turbo conversion with a ej207 (v6) if that matters since i'm using the TT top tank.
  8. Also tanks for pin outs sure it will come in handy in the future when im doing other stuff
  9. Hey guy just wondering if anyone knows where a diagram for v6 (or 5 cant remember if same loom or not)? Im doing a swap into my bh5 and need to add the boost pressure map sensor plug any help would be much appreciated
  10. Hey guys just a couple quick questions. 1 will any gc8 lsd fit on my BH? 2 what diff would be the best and is going to handle the most power as I'm planning on making my legacy the fastest in NZ over a period of time 3 could anyone give some info on diff codes (r180,200 ect) just for my general knowledge Any info would be much appreciated
  11. Selling my bh5 radiator and just wondering if it will also fit a bg5? any help would be greatly appreciated
  12. Hey guys im in the middle of dropping a v6 sti into my bh5 gtb and have v5/6 g4 plug in ecu for it and looking for a thread that can tell me what i need to do wiring wise for it to suit my bh5 or even a thread on the entire build. Any help would be greatly appreciated.
