McDoof last won the day on November 20 2023
McDoof had the most liked content!
Drives :
Mine 2014 VW Golf GTI
Hers NZ New MY08 Subaru Tribeca 3.6R -
Location
McDoof's Achievements
Motormouth (4/7)
43
When I got my headers I essentially booked my set on the liberty AU forum. They tend to let people know when they are doing a new run. The thread has been quiet for a while now though http://forum.liberty.asn.au/viewtopic.php?f=65&t=17262&p=447291#p447291
McDoof changed their profile photo
Anyone on here that knows how to program a remote for the Tribeca. I got a spare key programmed, which works fine. Immobilizer etc. However, the remote programming is not that same as the Legacy on which it is based. I can't find the white connectors to put the car into the learning mode for remotes. The key itself looks exactly the same as the Gen4 legacy key There is a procedure published all over the internet that involves opening and closing the door and turning the ignition on and off a few times. This does not work on the NZ Tribeca it seems. Also that would mean the remote needs an 8 digit code for pairing purposes. Which none of the remotes here seem to have. Any help would be appreciated. Thanks
Found this while cleaning out this morning. Dyno run from a while ago. 163kw at the wheels and a nice flat torque table. I will see if I can find the one that has the stock map on it too.
Yes, they are quite rare, especially if you want a facelift model. But worth the extra $$ if you want a car that is a true drivers machine.
I spent a lot of time working out the best mods for the 3.0R when I had it. By far the best to start with is an ECU remap. For remote tunes, if you have some patience and can deal with long waits, then Matt McLeod (kido tunes) does amazing work on the 3.0R. If you want someone responsive that does a reasonably good job XRT from Barbados does a reasonable job too. The Raptor headers do not add a lot of extra power, but they do free up the top end of the rev range so the car will rev freely all the way from a standstill to the redline. You could spend up large on a custom exhaust, but in reality all you need is the headers and then remove the 3rd cat from the system. Once you go to a bigger bore, even a 2.25" you will lose power in most cases. With these small mods mine was 164kw atw from memory. Which equates to around 210 at the fly. Don't buy an auto unless you really have to. The 3.0R with a 6 Speed has plenty of torque once tuned so you barely need to change gears in traffic anyhow. No need for a heavy duty clutch in these. The standard STI based unit works just fine unless you are supercharging it. The stock suspension is OK, but if you can afford some Sti pink springs or a set of swift springs it will really help the stance a bit and stop it nose diving a bit when you really push it. A rear sway bar upgrade really makes it turn in like it should and pretty eliminates the understeer that these have. That's my 10c
3.0r Budget exhaust build, after some info.
McDoof replied to LegacyBLErbd's topic in Legacy & Outback
Here are 2 vids of my old legacy. I went back to Stock mufflers after these which I found much nicer. Maybe not quite a budget exhaust build, but also not eccentric. In the videos I still have the Ultrex mufflers on. Raptor headers -> Stock Cats -> Custom 2.5 inch to the Y -> 3rd cat delete -> Stock mid section and then GT Mufflers because they have better tips. From my experience. 1. Keep the 2 stock primary cats. They really help keep the rasp under control. 2. The stock mid resonator is actually pretty decent. 2.25" straight through. 3. Straight through mufflers at the rear or modding your stock ones with some perforated pipe between the entry and exit should give you a decent increase in volume and tone. Adding sound deadening glass or steel wool to the casing will soften and deepen the sound. -
If you are on a tight budget and you don't know what you are after, then I would skip all the parts and start with a road tune from a reputable tuner. You'd be surprised at how much more you can get out of a stock car without having to upgrade any hardware. What gains are you expecting from fitting a FMIC?
I had mine done from one of those vouchers. Did a good job and still looks good a year on. Had my tail lights tinted at the same time. Company called Renewcar. Its basically a wet sand, polish and then a UV protection clearcoat to stop it from going yellow again.
PM me if interested. We can sort something out :-)
I have a Tactrix OP 2.0 in Auckland that can be borrowed. Maybe a small rental fee (box of beer) would cover wear and tear. I only say this because I'm on my second one because someone busted the first one when they broke the USB connector off.
The headers really only liven up the top end. They do nothing noticeable in the lower and mid ranges. That's right. It frees up the revs above 5500RPM according to the butt dyno. RSB will help a whole lot. Well worth it.
I think he does a pretty decent job of the GT too.
What are you doing for handling?
I kept my stock cats in place. I just removed the 3rd cat. The Headers to not bolt up. You need to cut the old headers out and weld the included flange in just before the cats. Removing the 2 stock cats is a bad idea. It will sound horrible unless you go nuts with additional resonators. It's very easy to get the sound wrong on these cars. I tried a bunch of things and ended up with the following Raptor Headers -> Stock cats -> Custom pipe to Y joint -> Stock mid section -> Stock rear Y section. You could replace this last Y section with something the flows better but your gains will be marginal (maybe 1-2kw) You can then play with the sound by changing your mufflers. The biggest gain by far is from having the ECU remapped. I had mine done by Matt (Throttle Happy) who is the best I have for the EZ30 but he's near impossible to get hold of and it can be very frustrating working with him. But the results are good. You have to be a very patient person and will need to try and get him as a friend on FB so that you message him. XRT gets some decent results too, but not at the same level. He is however much easier to work with and very responsive. Cryotune does not do a great job on the EZ30. He may have improved by now, but he did my first tune and it wasn't great.
Cryo is just another remote tuner. He should send you any links you need for software. In most cases you only need ECUFlash with the matching ECU definitions. http://www.openecu.org/index.php?title=EcuFlash
Who's Online 1 Member, 1 Anonymous, 188 Guests (See full list)
