• Announcements
    • ClubSUB.org.nz
      Mega Meet 2018 OUR 21st!   09/04/18
      We're turning 21! And we're celebrating on the weekend of the 12th & 13th of May 2018   Come join us Saturday and Sunday events including a FREE Lunch @ the Tui Brewery, Mangatanoka, for Subscribed forum members   A cruise after to the Karting Venue in Palmerston North   Following that Sunday is a Playday on Track event @ Manfeild    Join us for any one or ALL of the events & help get together to celebrate NZ's Largest & oldest online Subaru Community! ~ Joker
Cowtipper2016
  • Content count
    11
1 Neutral
About Cowtipper2016
  • Rank
  1. thanks mate its been doing my head in trying to describe it hahahahaha
  2. at the time of the oil change .. so 2500ks ago ... considering that first one had 1000ks on it im picking the fuel i got up north was S***
  3. Hey team! looking for a part number or better yet the actual name of this damn pipe! i have a 2006 jdm legacy spec b 6sp manual VF45 turbo EJ20Y looking for the pipe from the turbo outlet to the TMIC ... looks like mine has a leak and has crumpled down at the bottom Any help would be appreciated guys
  4. *update* ... 2500kms into a new oil change including resetting the ecu (via Btssm) this is what i got .. pretty happy with the results ... nothing has changed in the way i use fuel or where i buy it either
  5. i was a local there haha .. its my home town so was just up there to visit family and friends .. but for an AWD the gorge is excellent for running through as it pushes every limit the car has .. I actually live in Atiamuri between Taupo and Rotorua where there is an excellent gull that has 98 .. of all the terrible reviews saying Gull is bad and to use the likes of BP or Mobil i dont understand why as is see BP/Mobil branded fuel tanks filling that service station up from time to time
  6. I will try that on my next service in a couple weeks thanks @evowrx ... coincedently i have just finished building an 87 VL v8 wagon haha ... it's my weekend burn out machine
  7. sooo ... i did an oil change using good ol golf 10w-40 and stp oil additive which is essentially a zinc mix and make the oil stick to the walls abit better .. checked that banjo bolt which was one hell of a bugger to remove so i just unscrewed it to have a quick look before putting it back in .. when i was putting it in i punched a hole in the side of the filter .. thought stuff it ill just put it back in as i need the car running (its a daily for the misus) ... gave it a quiet run for abit till it warmed up then done a pull from 0 to speed cut .. results are below .. looking over them it didnt make much difference however i see the exhaust vvt on right bank is doing the same damn thing New Btssm run sincee oil change 0 to speedcut Thanks guys for your input
  8. thanks ill check that tomorrow .. just to be sure when you say left you mean passenger side?
  9. finally sussed out uploading a photo haha
  10. https://photos.google.com/photo/AF1QipObX6WvoQH4wbZ0Thf7a6sWR7tiB6iRRYlPYoFm This is the log file ... sorry if not formatted correctly I'll do that when I get home
  11. So I discovered the wonderful world of btssm and am loving it so far ... however when I had reset my ecu I had noticed a couple knock issues detected ... done just over 1000km since the reset on mostly highway conditions as well as some spirited driving over the maungamuka gorge (the log data linked shows the 8ish minute long and fun drive) ... after reading the log and checking my LV I am abit worried as most of the knocks come on at 4500rpm ... now it appears the LV has knocked my ecu down a few notches in the way of power... First off I am curious as to how this would happen on a bog stock 2006 JDM legacy gt spec b 6sp manual ... From my understanding this year was the change over year for example my turbo is supposed to be a td04 (from what i have read) but is instead a vf45 ... also being stick max boost target is 14.5 however I'm getting spikes up to 17 in some cases but more commonly around 15.5 for longer than a second Any help or suggestions are much appreciated Thanks
