If you use partsouq to plug part numbers into, it will generally tell you what the superceded part number is as well... so if the part specified for your car doesn't match exactly the part listed for the wrx... it still might be an equivalent part... and the superceded part number will be the same.
It's done via ride height, not preload... nothing should be unevenly loaded up when the car is sitting on a flat surface...
in fact aside from maybe the springs... no suspension components should be loaded at all.
The amount of height difference from corner to corner is minimal... the resulting even weight distribution means the car
is more predictable and balanced... not less.
A catch can setup does not need to be expensive or complicated. It is literally just a container with 2 to 3 inputs and one vent. The important thing is to make sure it is big enough to not overflow quickly and not restrictive, so the engine and heads can actually breather properly.
ok, so just setting the ride height... not corner weighting
btw you don't measure the ride height with the wheels off... not sure how that would even be possible.
You are going to need some spanners for sure. There must be about 200 threads about this on the forum. Have you searched? Sent from my SM-G930F using Tapatalk
That's a difference... a similarity is "removing a safety item because it might not work".
If he wants to remove the chance that a life saving device will work, good luck to him.
Hi Matt.
I stuck with the divided up pipe all the way to the turbo... figured there would still be some benefits from less
pulse interference. Whether it's that or the headers, the spool is better anyway.
Good to know... it helps to confirm my thinking then. Something I have discovered is just how meaningless a dyno chart is in some respects.
The divided 1.01 and single entry 0.63 with both spool almost the same on paper, but couldn't be different on the road.
