Koom
Moderator
  • Content count
    5,498
4 Neutral
About Koom
  • Rank
    Moderator
  • Birthday 11/07/31
    Mechanical Engineer with expensive hobbies.
    ChurChur
    Designing Stuff
  1. V-Limited's, both STI and non, also have the helical front diff.
  2. I've never found Blacks to be the cheapest, but this kit isn't too badly priced. http://shop.blacksfasteners.co.nz/#/Product/info/COILB40293
  3. If your car has a Cert, changing tyre sizes doesn't effect it. The height on the Cert Plate is the relationship between the hub centre and the guard, which doesn't change when changing tyre profile/width. The Cert does usually lock you into one particular wheel size i.e. 17 x8. But not the offset.
  4. http://www.hardrace.com/Product_detail.asp?id=2807 I'm pretty sure that something just like that is what Tony used. Then modified the rack ends to be height adjustable to adjust out the bumpsteer. But the angle of your axles is dictated by the wheel centre and the height of the gearbox. If you want to go lower, you can't fix the angle of the axles by adjusting anything at the hubs, you'd have to lift the engine/gearbox up.
  5. I doubt that it's possible as the CV joint would need to be in the same location as the strut mount. There are Roll Centre Adjuster kits which will achieve a similar result. Also need to correct the bump steer if the kit doesn't contain those parts.
  6. The lower the level of Rallying, the louder the anti-lag must be set up! Its a rule haha. A proper antilag setup these days involves fresh air recirculation and a lot less popping and banging than what used to happen in the Possumlink/Link G3 days but I still wouldn't go anywhere near it unless you really, really need it. Cause it's otherwise a massive pain in the a**.
  7. No worse that a service park during a Rally. Except it should also be either a) raining, or b) freezing and windy. Also add in a predetermined time limit and a grumpy driver who's busy watching the time penalties stack up
  8. I'm guessing you mean chromoly? Which is a steel alloy that's generally tougher than plain steels. The factory ones are steel. Possibly plain carbon steel or low alloy content but likely to be chromoly as well. You could get some made but the cv's prevent you from making a super strong axle. As any axle is limited in outside diameter by the spline that fits the cv's at either end. Have you looked at the driveshaftshop.com to see if they do an upgrade axle/cv set for your car?
  9. 10% of 10.5" is 27mm 35% of 10.5" is 93mm So max/min offset of +27/-93 But I don't know how that equates to the factory wheels which are outside of that? But that also states that it's for transversely mounted engines too. Subaru's are longitudinal. Might be easier to post a question on the lvvta forum and get an answer straight from the horse's mouth. Or talk direct with a certifier. What flares are you planning on using?
  10. Nice result! What fuel is that on? Just pump gas or gone for an ethanol blend?
  11. Attacked it with a grinder and then the welder. Pretty much rebuilt the up-pipe and downpipe so far. All to move the turbo 10mm (+ decrease the angle it's mounted on) and fix up a leaking wastegate. Might even make a decent heat shield for the brake and clutch masters this time round!
  12. Did the seat get left out of the wastegate when installing? Although that wouldn't explain why it can't hit peak boost, but would cause it to be slow to start to make boost.
  13. From memory, yes, that is the case.
  • Who's Online   0 Members, 0 Anonymous, 7 Guests (See full list)
