churr people
thinkn ahead and sortn out which ecu im gonna use and decided that im gonna pull out the chipped one and chuck in the possum link at some stage.....
heres my issue....
what would be the best way to go with this regarding serial links and hand controllers,
ive been offered a hand controller from a member on here,
but then a serial link has just come up and its cheap as so im thinking maybe thats a better way to go as my possum is laptop tunable....
not sure which is the best way to go,
your thoughts.. 8)
na the box hasnt been splitt from the motor in over 2 years.........
when the clutch is in i can feel it, pushing/tapping against it.
im starting to think that maybe a bolt or tool or something has fallen thru the hole at the top of the gbox housing
and is jammed somehow at the bottom and the flywheel is touching it ??? ???
if this is the case whats the best way to resolve/fix this ???
and yea i like that wastegate too...
seems a waste tho as its brand new and now another issue comes up :
hasnt even had any boost in it.....yet
set my fuel pressure again this morning with the vac hose off.......
set to as close to 43.5.
when i turned car off and hooked up the vac line and started it up again the pressure drops to around 30-35.
my question is , is this normal??
when i gave it gas the psi increased and then went down like (i assume) a rising rate fpr should......
running a tomei fpr with an mechanical gauge (not liquid filled) ??? ???
went out and started it again and now im thinking it could be something other than the BeB.....
when the cars running you can feel a tapping on the clutch pedal....
when i say tapping i mean it feels like theres some one tapping it from the other side....
and if i give it some gas the noise and the tapping feeling on the clutch pedal increases.....
has anyone come across this before?? is that what happens when the BeB goes??
im starting to think that maybe a tool or nut/bolt may have fallen down the hole where you can see the fly wheel???
but still unsure ??? ???
i didnt think it would be my big end but since,
the car has been sitting for a year and a half and hadnt had a oil change i thought maybe its that...
but i have never heard this sound nor the sound of a big end on anyone elses going im not too sure what it is..
sound seems to be coming to be coming from the block around the crank ???
im still going thru you tube to try find something similar
so i finally got my car up an running yesterday took it to get exhaust welded up gassed her up and she seemed to be running sweet as....
never thrashed her went easy when i was driving as she been parked up awhile
was running low on gas so i parked it up till this morning.....
anyway chucked in some 98 and started her up and F#@ ME sideways.....
someones knocking on the door!!!!
can some one confirm what this is....i think i already know what the answer is 8) 8) 8)
i rekn ALL them people involved atleast got what they deserve and if it was mine that was takn there would be hell to pay and you cant hide in jail 8) 8) 8)
even if you go admin segs.....i can still reach you in there ;)
