EJ20T
    GGA, CP9A
    Mount tauranga
EJ20T's Achievements
Motormouth
Motormouth (4/7)
3
  1. Hey is this open to other brands? No longer got a Subaru but keen to bring my mitsi along
  2. Check every fuse propery, most times you will pop the fuse for the power feed from the alternator
  3. Yeah need some figures, and open loop mixture shouldn't have a massive effect on fuel consumption depending on your driving style
  4. yeah, and don't buy them from repco, they are ****en rip off
  5. I have actually been around since 2004, I got a paid membership back then but it wasn't really worth it out in whakatane
  6. go with the hankook ventventus2 if they are the same price, Achilles are rubbish,ive fitted landsails and delintes at work, both Chinese with soft rubber, chewing gum sidewalls
  7. you need to remove the banjo filters at the supply, you need to remove the sump and clean it because it will be full of bronze from the internals of the turbo
  8. Dude I bought a tomei item off them......never again it took like 5 months not impressed
  9. I wouldn't recommend using it depending on how rusty it is. The fuel filter is actually not very good at stopping fine slit type rust. Blocked the injectors on my evo
  10. 2001 GGA wrx 1998 Evolution V 1994 hilux surf
  11. Dont think about legnums, they are sacks! I would know I worked on them for years
  12. They will do just fine, 'power' isnt so much the important figure, torque is more the major figure because its directly connected to cylinder pressure
  13. For sti dual avcs only came in on the v11, regardless of being 2 or 2.5ltr. Buy a ver9!
  14. I have a similar issue with ecuflash trying to read out ver7 impreza ecus
