My sad STi..
funkytown
whats your money on being wrong with my wagon
42 members have voted
  1. 1. whats your money on being wrong with my wagon
    • running WRX heads, not STI
    • bung block - head gasket
    • Bung block - valves are screwwy
    • Dead Turbo
    • i have gremlins and they stole my ponies
    • Poos tune or somehow the driver doesnt have mental capacity to squeeze the throttle right to the floor
    • other - post up what you think
 Davebro']
[quote name='nzkaosnz said:
i pity the ladies. you cant find the word, let alone the love button.
I thought this was a public forum??????
Im just keeping it clean.
I have no problems with the ladies, the buttons or anything.......
Where is the real Dave and what have you done with him!!!
  • Replies 129
 Odie']
Im just attempting NOT to get another warning........
it gets worse people..
My clutch is munted, needs to be replaced, and spigut bearing seized (sp.)
The turbo is also poked - as per popular opinion, has a couple of bent blades and has lots of debris on all blades. turbo has gasket cement of the exhuast side so may have damaged exhuast wheel as well...
The up pipe was completely in two peices... or "rooted" as rick said.
Has the block out and he tells me its also likely got seized gudion pins(sp.) or nearly done a BEB.. is currently investigating..
this is where i break down and wonder what the hell im going to do.. or how much worse it could get.
i think the poll should of been how many Kw's i actually pulled on the dyno and at Taupo...
120 i think would have been very generous...
Guest SPANKU
it must be one of those special hand shaking that we done as it all my corsed lifted to you.... welcome to my world where we do nothing but spending our hard earn money on our car, fixing or doing it up....
bottomless money pit group
So heres more from rick...
new engine time or rebuild...
Well looks like the noise is from the gudgeons ( appears to have had small end bearings replaced ) SEB
And they are way too tight
The engine has STD size factory HF forgies, the crank bearings have been done and the crank has been ground to 0.25mm on mains and 0.75m on big ends
These bearings are quite worn and will need replacing. Essentially the engine needs full rebuild
I can't believe that the engine wasn't using water,as the main case bolts seals where missing on 2x bolts !
One of the case O-rings for the oil pressure feed was split in half !!
I'm off now to the reconditioner with armfulls of parts to be measured and assessed.
Will hold off doing crank repair until we have a full damage report from them
Why not just junk it all and buy a new motor from Possum Bourne? Use your accessories and your new turb and way you go.
All up about 5g. My rebuild was $5500!
And youd be surprised how often the crank pulleys come off boxer engines a!
WARNING. Check your crank pulley bolts on servicing. YOu need to wind the hell outta them!
They arent held on by much thread.
Seems alot of the trouble you may have had in the bottom part of your motor maybe those other parts being tight and making your motor work more. A couple thou clearance here and there dont take alot to chuck something else out.
If its been rebuilt before mate it certainly not your fault. Just one of those thing. Get your mate to get it all checked and if you have comeback youll have ammo.
 funkytown said:
looking that way.. thinking new short block is going to be the way to go.. did that rebuild include labour, clutch, turbo?
I can scan/email the receipt to you if you want?
That was just labour to fit it all together mate.
holy crap, I think you may have got a little of my curse too.
dont forget i've got the vf28 there, price negotable. I'm about to pull my engine out of the car, I've already ordered a new HD clutch, i'll let you know if my old one is in good condition
Guest SPANKU
well at least the TUNE got nothing to do it with!
i said it was the turbo and the rebuilds ( though it was the rings?)
think a standard STI replacement will do the goods, capable of taking more grunt from the engine and is not a part i need to throw money at.. have a replacement sti number in my GTB and i liked it..
Its the engine and turbo combinations and flavors that dazzle me - thanks rick ;)
and also thanks to rick for the countless phone calls to date... descriptions, and options, photos and even the video. Is happy to describe everything along the way thats for sure.
