A helpful hint...re dim A/C display
matt1710
Hey
I've suffered for years when driving with the headlights on as the A/C controls dim automatically - making them unreadable unless it's night time. So when I stumbled across this tip (here in the forums) I thought it deserved some publicity:
Once the headlights are turned on, hold down the 'OFF' button on the A/C temp dial for 3 seconds...it will beep and then the display will return to normal brightness. BINGO!!! ;D ;D
This works in my 2000 GT-B E-Tune - hopefully for other models/vintages too.
 Divine said:
Work for Gen1?
I don't think so. My old NZ new gen 1 had a "bright" button for the clock, but the earliest I've seen the A/C brightness adjust is on a gen 2.
Wonder if this will work on my Forester... *goes and gives it a go*
Edit: It does work! Though as soon as you push another button or turn off and on the lights it resets and you have to hold down the button again. Only have to hold it down for about 1 sec though which is nice.
Edit Edit: Apparently it is 14degree's outside. Just thought you'd want to know.
  • 3 months later...
  • 10 years later...
