Sign in to follow this
Followers 0
Swindog
Intercooler and Other Related FAQ's
1 post in this topic
Intercooler
What is intercooler heat soak?
What is the purpose of an Intercooler?
FMIC, TMIC, SMIC - what do they mean?
Will an intercooler help make more horsepower?
What is the difference between an air-to-air intercooler and a water-to-air (liquid-to-air) intercooler?
How do I select the proper intercooler core size?
What is the best placement of my intercooler?
Will a FMIC block flow to my radiator?
What is intercooler effectiveness and how do I measure it?
What exactly is 'pressure drop/loss' / 'flow loss' and how are they measured?
I want to turn up my boost, is a larger intercooler necessary?
Is there a maximum amount of boost I can run on my intercooler?
How significant is a leak in my intercooler?
I want my car to remain a sleeper/stealth. Can I paint or anodize my intercooler so it is not easily visible?
Is there any maintenance required for my intercooler? Are there any special things to do to keep it working longer?
Heat soak is when the intercooler can't dissipate the heat that it absorbs from the turbo fast enough. When an intercooler can't cool the charge air by removing the heat from it, it loses its effectiveness. This explains why turbo cars tend to run slower or have slightly less power when the weather is warm.
An intercooler's primary function is to cool the charge air after it has been heated due to boosting and the heat that is produced by the turbo before sending the air into the engine. As the air is cooled, it becomes denser, and denser air makes for better combustion (more power). Additionally, the denser, cooler air helps reduce the chances of knock.
(Front Mounted Intercooler, Top Mounted Intercooler, Side Mounted Intercooler) terms which refer to the placement of the charge air cooler in the engine bay and in reference to the engine. Typically FMICs provide the best cooling capability, as they are located in front of the radiator for optimum airflow. SMICs and TMICs are commonly found on factory-turbo'd cars. TMICs are more prone to heatsoak as they are placed over the engine directly in the path of the rising heat and very close to the hood. However, when a TMIC is used in conjunction with a hood scoop, they can provide adequate cooling.
Yes, although it is only indirectly responsible for helping make more power. Since the intercooler increases the charge air density, an intercooled engine will typically make more power than a non-intercooled engine with the same setup by allowing more air to be crammed into each cylinder.
An Air-to-Air intercooler uses ambient air flowing over the fins to cool the charge air, while an Air-to-Water intercooler uses coolant (water) with a system similar to that of a radiator's cooling system. Traditionally, air-to-air intercoolers are used for street applications because of their lower cost and reduced complexity, while air-to-water intercoolers are used in race and packaging-constrained applications.
A major limiting factor in choosing an intercooler size is space constraints within the engine bay. If there is not enough room for an intercooler with adequate flow, then often a water-to-air intercooler is used instead to maximize the cooling capability of the surface area of the core.
You want to make sure that the intercooler you choose is large enough to effectively handle the air. Too small of a core, and you will restrict the potential of the turbo by not allowing the charge air to be cooled adequately.
The best place for your intercooler is directly in the path of the inflow of ambient air. Traditionally this has been right in front of the radiator in the front of the car, hence the term Front Mount Intercooler.
No. Since the intercooler allows air to pass through it, airflow to the radiator will not be blocked. However, using an intercooler core that is too thick and does not allow air to pass through it quickly or completely and airflow to the radiator can be restricted which can lead to potential overheating problems.
Effectiveness is defined as the ratio of how many degrees of temperature that were removed from the charge air by the intercooler to the original temperature that is put into the charge air by the turbo.
Example:
If the turbo compresses the charge air to a temperature of 140° F, but after passing through the intercooler the air is 115° cooler (resulting in a 25° F charge air temperature), the efficiency would be:
Effectiveness: 115/140 = 0.82 or 82% efficiency
Typically, air-to-air intercoolers for normal street applications range between 60% and 70% efficiency. Often, liquid-to-air intercoolers have effectiveness ratings from 75% to 95%. One common method of improving the cooling of the charge air dramatically in an air-to-water intercooler is the inclusion of ice as a coolant.
Pressure loss, or pressure drop, refers to the change in pressure when comparing the air entering the intercooler with the exiting air. This change is mostly affected by the internal flow area of the intercooler. Flow loss, however, is measured not just with pressure loss but with how much restriction to airflow exists.
Maximum performance can be obtained if the pressure loss is kept below 1.0 to 1.5 psi. Anything in excess of these numbers, especially higher than 3.8 psi, and the intercooler is not properly fitted for the application which results in hindered performance and dramatically decreased functionality of the intercooler system itself.
Usually, it is not necessary to upgrade the intercooler when raising boost levels. The pressure drop contributed by the intercooler is proportional to it's flow (CFM) squared. This relationship shows that it is highly unlikely the change resulting in loss from higher boost levels will require a larger intercooler. If there is a significant change however, such as 40% or 50%, then a larger intercooler may be necessary.
While it is possible that an intercooler can fail from boost levels being too high, it is a very rare scenario. However, if not properly designed to handle high boost, cracking along seams and of the endtanks can occur.
For an air-to-air intercooler, a leak, as long as it is not a significantly large one, will not hinder performance at all. However, if an air-to-water intercooler develops a leak in the main core, it could lead to other more significant problems with the engine itself. Be sure to fix these problems as soon as they occur to prevent other damage.
Yes! It is not uncommon at all for an intercooler and endtanks to be anodized black to keep attention away from the car and help it maintain a sleeper appearance. A very light coat of paint on the core and endtanks is also another option, usually much cheaper and easier than anodizing, with a negligible performance loss.
In a water-to-air intercooler, check the water level often as this is crucial for the intercooler to operate properly. In cold weather, just like a car, it will need antifreeze in order to function effectively and properly. With an air-to-air intercooler, there really is no maintenance that needs to be done other than just the routine checking of hoses and clamps to make sure everything is tight. Additionally, the intercooler fins may be picked-out or de-smashed to ensure maximum cooling. Every 20,000 miles or so it is recommended that the intercooler core be inspected, and if necessary, flushed/washed out to remove any accumulated oil or buildup.
Other
What other systems are affected by turbocharging? (Fuel, Oil, Cooling, Drivetrain, etc)
How is boost measured? (Bar, mmHg, PSI) and How do you convert from one to another?
The turbo gauges measures turbine speed, right?
What is a boost controller?
Which boost controller should I get? (Manual or Electronic)
How much boost can I run on pump gas?
What is Knock/Detonation?
Should I run a Turbo Timer?
Do I really need the cool down procedure on my turbo?
How can I remove and clean the oil condensation box/oil catch can?
What is the purpose of an oil catch can?
What additional maintenance is required for the turbo?
What compression ratio should I run with my turbo engine?
How do I adjust my compression ratio?
Should my turbo/exhaust manifold glow red after driving?
What should I look out for when buying a turbo?
Are oil deposits indicative of impending turbo failure? There is blue/black smoke, is my turbo going bad?
How fast will my car go with xyz?
What is the Inducer?
What is the Exducer?
There are several factors that must be addressed when deciding to turbocharge a previously naturally aspirated engine, such as: Is the current fuel delivery system capable of providing increased, adequate amounts of fuel? Is the cooling/oiling system capable of handling the extra power and consequently, extra heat that is generated by the turbo? Is the clutch/transmission/drivetrain up to the task of handling the extra power? Etc
Boost is measured as the pressure that the turbo creates above atmospheric pressure.
Normal Atmospheric Pressure (1 atm) = 14.7 psi = 760 mm Hg
1 Bar is not actually equal to 14.7 psi, but rather it is equal to 14.5 psi, = 0.9869 atm = 750.062 mm Hg
The "turbo gauge", commonly called a boost gauge, does not measure turbine speed. It measures the intake manifold pressure. Under light loads the boost gauge will indicate a vacuum due to the turbocharger shaft not rotating fast enough to create positive pressure (boost). Once load (throttle position) increases, the boost gauge will indicate a positive pressure.
A boost controller is a device that bleeds or blocks the boost pressure signal entering the Wastegates actuator. The idea is to keep the Wastegates closed to allow higher boost pressures than the actuator would otherwise allow. These can be simple mechanical or sophisticated electronic devices, with price tags to match.
Boost controllers vary widely in performance, price, and functionality. For a comprehensive breakdown of some of the more popular options, see the July 2002 issue of Sport Compact Car Magazine.
The primary limitation to maximum boost is engine knock. It is also not advisable to run the maximum amount of boost your car can handle on a daily driven basis as a precaution against if the boost spikes.
Knock is a condition caused by abnormal combustion of the air/fuel mixture and can result in damage to an engine.
The three factors that result in engine knock are: 1) knock resistance characteristics (knock limit) of the engine, 2) ambient air conditions, and 3) octane rating of the fuel being used.
Since every engine is vastly different when it comes to knock resistance, there is no single answer to "how much." Design features such as combustion chamber shape, spark plug location, bore size and compression ratio affects the knock characteristics of an engine. In addition, engine calibration of fuel and spark plays an enormous role in dictating knock behavior.
For the turbocharger application, both ambient air conditions and engine inlet conditions affect maximum boost. Hot air and high cylinder pressure increases the tendency of an engine to knock. When an engine is boosted, the intake air temperature increases thus increasing the tendency to knock. Charge air cooling (e.g. an intercooler) addresses this concern by cooling the compressed air produced by the turbocharger.
The octane rating of fuel is a measure of a fuel's ability to resist knock. The octane rating for pump gas ranges from 85 to 94 while racing fuel would be well above 100. The higher the octane rating of the fuel, the more resistant it is to knock. Since knock can be damaging to an engine, it is important to use fuel of sufficient octane for your application. Generally speaking, the more boost you run, the higher the octane requirement.
A turbo timer enables the engine to run at idle for a specified time after the ignition has been turned off. The purpose is to allow the turbo to cool down thus avoiding "coking" ("coking" is burned oil that deposits on surfaces and can lead to blocked passages).
The need for a turbo timer depends on how hard the turbo and engine is used. Running at full speed and full load then immediately shutting down (heat soak) can be extremely hard on a turbo. Water-cooling of the turbocharger's center housing has essentially eliminated the need for turbo timers or extended idling periods.
The need for a cool down procedure depends on how hard the turbo and engine is used, and whether or not the turbo is water-cooled. All Garrett turbochargers must pass a heat soak test and the introduction of water-cooling has virtually eliminated the need for a cool down procedure. Garrett is one of the few turbocharger manufactures that subjects their turbos to several OE qualification tests. When you buy a Garrett turbo you can be sure it's a reliable one!
The oil condensation box, or catch can, can be cleaned once it is removed with any cleaning solvent. Simply fill the box with a cleaner and slosh it around until oil deposits are gone. Removing the oil condensation box can be a challenge and varies by vehicle.
NOTE: some vehicles are not equipped with an oil condensation box.
An oil catch can's purpose is to catch oil blow-by gasses that can eventually create a carbon and oil sludge build-up in the intake and turbo.
Good, clean oil is extremely important to the turbocharger. It is best to change the oil and filter at least as often as the automobile manufacturer recommends. FRAM produces replacement oil filters for all levels of server use. Visit www.FRAM.com to select the right filter for your application!
Turbo performance is sensitive to turbo inlet conditions. A clogged air filter can drastically affect the turbo inlet. Air filters should be inspected at every oil change and replaced at 12,000 to 15,000 mile intervals. FRAM produces replacement air filters including a new performance filter the FRAM AirHog.
NOTE: Never exceed the vehicle manufacturer's recommended filter change intervals.
Allowable compression ratio depends on many factors, and there is no one right answer for every application. Generally, compression ratio should be set as high as feasible without encountering detonation at the maximum load condition. Setting the compression ratio too low will result in an engine that is a bit sluggish in off-boost operation. Setting it too high however, can lead to serious engine problems due to knock.
Factors that influence the compression ratio can include: fuel anti-knock properties (octane rating), boost pressure, intake air temperature, combustion chamber design, ignition timing, and exhaust backpressure. Many modern engines have well designed combustion chambers that will allow modest boost levels with no change to compression ratio, assuming appropriate tuning. For higher power targets with more boost, compression ratios should be adjusted to compensate.
The easiest and most effective way to accomplish this is through the use of either higher/lower compression pistons, and/or using a head gasket of a different thickness.
Yes, the turbo/exhaust manifold can glow red under certain driving conditions. The exhaust gas temperature can reach over 1600F under high load operating conditions; i.e. towing, extended uphill driving, or extended high rpm/boost conditions.
Condition of the turbine housing - inspect for cracks on the exterior and inside the inlet of the housing. If the housing has cracks then the housing needs to be replaced.
Condition of the turbine and compressor wheels - inspect for cracks and damaged blades. If either of the wheels are damaged then the wheel (s) need to be replaced and the center section balanced.
Condition of the bearings - spin the turbocharger shaft and check for roughness. If roughness is detected then the turbocharger needs to be disassembled and the internal components inspected and replaced if necessary.
The most important factor is to make sure the turbo is the proper one for your application. A properly matched turbo will provide better performance and more reliable operation. A properly matched turbo includes matched turbine and compressor wheel sizes and appropriate housings.
Blue/black smoke can be caused by numerous conditions, and one of them could be a turbocharger worn past its useful service life. The following are potential reasons that blue/black smoke could occur:
Clogged air filter element or obstructed air intake duct. This condition creates a vacuum due to high differential pressure resulting in oil drawn into the compressor and subsequently burned during engine combustion.
Engine component problems; i.e. worn piston rings or liners, valve seals, fuel pump, fuel injectors, etc.
Obstructed oil drain on turbocharger resulting in pressure building inside the center housing and forcing oil past the turbocharger seals
Damaged turbocharger or turbocharger worn past its useful service life
Black smoke is also sometimes indicative of too rich an air/fuel mixture.
This question cannot be answered as how fast any given car will go depends on the unique individual setup, road/weather conditions, and of course, the driver's skill.
Looking at a compressor wheel, the inducer is the "minor" diameter. For a turbine wheel, the inducer is the "major" diameter. The inducer, in either case, is where flow enters the wheel.
Looking at a compressor wheel, the exducer is the "major" diameter. For a turbine wheel, the exducer is the "minor" diameter. The exducer, in either case, is where flow exits the wheel.
Compressor wheel exducer diameter is incorporated into Garrett GT-series nomenclature: The "60" in the GT2860RS for example, has a 60mm compressor wheel exducer diameter
Share this post
Link to post
Followers 0
    • Steve
      Hi all. So I've just seen on Facebook about a thing called The Gumboot rally it's on the weekend of the 7th of April. Goes from Hamilton somewhere down to New Plymouth then across to Taupo and also includes The Forgotten Highway which is an awesome road to drive, as I have done it a few times now. If you are interested go have a look on Facebook should be a fun weekend I reckon.
      Stay safe on the roads over this time there are some CRAZY people out there who only think about themselves!!
    • Steve
      Anyone going to Automania Auto festival tomorrow up at North Shore events centre?
    • Steve
      Does anyone else on here know or own one of the crouching tigers?
    • Matty t  »  gotasuby
      Help me please Hi iv fitted a dump valve to my vectra c 19 cdti 150 bhp. The 1 I bought was a twinport or receculation valve I don't no just bought and had a go of fitting it my self.  On looking at the car I thought I needed to block the 2nd port so have done bought a t and fitted it on the main intake Of The top Of The intercooler to the inlet on to Of The head.  Ran the bleed pipe and td it in to the on top Of The intake now it's just realeasing through the revs rather than when I lift of it's not because I blocked the other port is it thanks
    • WKDWRX
      https://www.instagram.com/p/BPPX4eLDujb/
