1999 b4 manual conversion
josephstef
i have a 2001 GT-B Legacy E-tune Twin Turbo ECU out of a Manual.
Its a 3 Plug (same as WRX v5/6 plug layout), number one thing to check if this ECU is compatible is to check and see if your car has the same plugs (as per pic)
If the plug arrangement is the same the next major thing to check is youd need make sure your engine is the same compression ratio as the manuals (some one may know on here) and i guess another good referance is to have a look and see if you have yellow injectors.
$60.00 + postage
