Subaru Turbo System explained
Stoffa
Just to add thats only correct for 2 port bcs.
Some subs came with 3 port thus no restrictors from factory.
1st Gen Legacy ? v4 Sti and 22b maybe others...
 GC8E2DD said:
Great explanation! I wonder what kind of aperture the prodrive solenoid uses that negates the need for the pill. Would it be fixed (ie; it is effectively a pill), or somehow more cleverly regulates?
3 port solenoid
Good on you for doing a bit of good research.
This is a good piece of imfomation for any one that has over boost problems or just wants to turn up the boost correctly with out using a cheap bleed valve because as you can see the factory system is not to bad up to a point.
-My old v4 import rans a 3 port solenoid & a pill. The pill works the same put the solenoid works as the Tee piece & valve in one. = the same out come.
I have had to ditch my pill & factory stuff & am now running a EBC. But like i said it works good up until a point.
-The prodrive unit they talk about my either have no pill because?
-The solenoid has a set amount of flow restriction.
-The ECU controls the solenoid so it might just hold it closed or open for longer the same as an aftermarket ECU or boost controler can?
  • 8 years later...
This version maybe clearer
https://www.perrin.com/blog/post/boost-control-systems-explained-part-1
https://www.perrin.com/blog/post/boost-control-systems-explained-part-2
https://www.perrin.com/blog/post/boost-control-systems-explained-part-3
Same deal more articles up one level
https://www.perrin.com/blog (WARNING: contains evo, mini and other brands. Subaru owners may experience an adverse reaction)
Edited by Gripless
