Attn, ALL OWNERS OF CARS THAT HAVE AVCS
 Ichi Ban said:
When do you wan the modified sensors to fix your car?
They are currently in Napier for a workshop doing a swap over of sensors, will have them back on Tues and ready for you on Thurs
Don't have time and funds atm to deal with it presently, but it's on the "to do" list now >:(
 pappu said:
is this the 2 avcs sensors that need to be sorted??
Seen here with manifold removed -
Job is fairly easy (in my opinion) you just need to undo one bolt (10mm head) on each sensor to remove
Skinny fingers help and a bit of patience
Firstly locate the sensors and the securing bolt
air box and washer bottle out are a must and intercooler too if you need extra space
Then its a simple swap over
I can do them in 30min ( for the pair of them ) but allow yourself an hour a side
 deathz0r said:
I've just done this to my engine and should have some pics for everyone. There was definitely oil there! Nasty s***, but it's all gone now!
how have you stopped the oil from entering the loom?
  • 4 weeks later...
I need this checked/fixed + AVCS filter baskets pulled (if that's a good idea?) and probably just a general Ichi Ban check-over... I'll do it after I do an oil change, what sort of advance notice do you need and what's your rate? PM me if you like.
  • 4 weeks later...
Hey there, usually need a weeks notice to make sure i have a pair of modified sensors ready to go in
Have just got a pair back from Napier, and they are in the process of being sorted now
"petrolheadJ" needs a pair fitted, but not thill the end of the month
before or after oil change is fine
PM me to dicuss rates
a special 2 pak resin ( and no I wont tell, as I was the one who has done the research to find out how to fix them and what works and what doesnt )
The resin is used to seal the sensor completely
New orings installed and sensor is tested for correct resistance and insulation
Fair enough :)
to be honest I have only seen 1 H6 sensor fail - and from memory the sensor was very similar to the Leggy and rex
Have done many repairs to H4 AVCS sensors - dozens now
yay just found oil in my 16 pin plug up near boost solenoid, have to figure out how to remove the sensors and get them to you Rick. There wasnt much (I have seen about 10-15mls in a different car) mine had 2-3mls so I will consult with Auckland based members on removal and get in touch with you
all good, have a pair of sensors here, rebuilt and tested ready to go
I can send them to you, and you send your ones back to me once you have done the change over
  • 5 months later...
  • 1 year later...
