Dumb Question Thread!
Jambun
 BINKZ said:
Is there any real benefit to upgrading BH5 brakes from 2 pot to 4 pot front caliper or is it simply cosmetic?
Have them on my BE5, obviously can't compare them to non four/two pot. But it does stop really good even with average pads. Definitely doesn't feel the 1.5 ton that it is, really good feel as well. Will go for good pads when these ones die and possibly do brake lines as well.
Edit: also big red brakes look great and add 5kw.
If you're not tracking your car regularly or doing any real strenuous driving, I'd stick to good pads and good fluid. Until you score 4 pots for super cheap.
 al said:
Anyone have a throttle jam open? Mine jammed at about 6000 rpms last week. I found the tiny rubber boot that protects the end of the throttle cable had fallen down the cable to under the throttle linkage. Would this have caused the problem?
Your bang on the money. Had this problem myself. Although it happened to me the day I brought my type r. Thought I brought a lemon! Almost shat myself
Got a dumb audio questions
Bought a high to low level converter, using it to get a signal to the new sub. The rca output is just left and right which makes sense but the high level input has left +ve and -ve, right +ve and -ve which has me a bit stumped as the stock sub has the expected +ve and -ve. Should i go across from left +ve to right -ve like bridging two channels on an amp or something else??
3AEF39BC-57A8-4360-9BCE-A11924B6840C_zps
Don't worry about it, the rubber intake hose muffles a bit of sound and now you're hearing it louder.
If the airbox doesn't seal right then just use a bit more effort to make it click into place, or fiddle with the silicon joiners on the Z/S hosey thing
  • Guest locked this topic
