Dumb Question Thread!
Jambun
 Percy said:
Like this one?
http://www.trademe.co.nz/motors/car-parts-accessories/tools-repair-kits/other/auction-896018487.htm
I have a Powerbuilt one, dont think it was $60, more like $20.
Not as flash as the one above, but it does the trick, still have to manually pump the pedal and check the reservoir though.
Only took me about 45 mins to bleed the whole car, and that included getting it into the air and back down, which is a pain cos my jack doesnt fit under the front...
Yeah one of those. Just want something I can do on my own without annoying anyone else.
The ones that pressurise the reservoir are bloody good, especially if they automatically keep the fluid level up, but that Tardme one isn't one of those.
You can make a ghetto self bleeding kit, you just need something to stop any air bubbles getting back down the line into the system, ziptieing the bleed line up to things above the nipple height works!
Mine is like the one below, just not SCA branded!
http://www.supercheapauto.co.nz/online-store/products/SCA-Brake-Clutch-Bleeder-One-Man.aspx?pid=291149#Recommendations
Does anyone know of a good place to get suspension control arm bushes replaced in Christchurch on a weekend. I have the bushes just need the press to change them over and can only do in the weekend (preferably Saturday)
PMed SAS?
 wrx_lou said:
Do you need to pull the engine out for a single conversion or can you get away with it sitting in place?
If yiu are cunning you can do it in place its a prick of a job to do in place.
you will need to drop exhaust manifolds off and take intake off to get access to everything nicely can defintely be done makes putting single turbo oil drain and water pipes not so much fun though
Edited by tydon
  • Guest locked this topic
