Dumb Question Thread!
Jambun
Need to cv joint done on my 99 impreza wrx sti v5. Have got a great price via repco for the full drive shaft. So inner and outer cv plus shaft. What I am wondering is if anyone have used this part from repco and did it all work fine?
Price was 100 inc gst so really cheap if the quality or parts is good.
 revive']
[quote name='kwi_fozze said:
That sounds.... Suspect
Mates a area manager for repco so it's hookups to get that price. Just curious about the quality
Chinese I believe...not a whole lot of options on axles aftermarket.
Subaru Legacy TS-R 1998 2L, had the dash out and heater core replaced, now the main AC fan makes an extremely loud buzzing/rumbling noise when put on max. It's bolted in as tight as it'll go.....
Also, got an air-pocket in the heater core, have tried 3 times to bleed the system but it ain't budging (thermostat 1 month old too so not that). Recommend taking the hoses off and back flushing the core, and re-trying?
have heard of people jacking the front of the car up and bleeding the core. unsure on how effective this is
 kwi_fozze']
f**k that makes no sense....
Dampner adjustable suspension doesn't require cert?
i.e. Does suspension that has only damper adjustment require a cert? NO.
[quote name='Jambun said:
ALL height adjustable suspension requires cert?
Does all (non-factory fitted) suspension that has height adjustment require a cert? YES.
So "We are borg" had the perfect answer. Whats so hard to understand about that? Makes perfect sense.
  • Guest locked this topic
