• Announcements
    • RAYDEO
      ClubSUB 2018 Calendar is now avilable!   24/09/17
      Click here for more info!
      The 2018 ClubSUB Calendar, Powered by Possum Borne Motorsport is now available.
      12 Hand picked full colour photos, taken by menbers, submitted by members and chosen by members.
      All vehicles in the calendar are owned by members of the NZ Subaru Enthusiasts community.
      A massive thanks to the team at PBMS for coming on board for another year!
      This is a very sought after calendar and only available for a limited time.
      Also, if you are a subscribed member of ClubSUB, you will be in for a descent discount, so make sure you're logged in.
      Please note, as these are printed to order, shipping will be delayed. we will make 3 orders, October 30th, November 27th, and December 11th. If you dont order intime to make one of these shipping dates, we will get it out to you in the new year.
Jambun
Dumb Question Thread!
6,434 posts in this topic
I've got a 2 port boost solenoid, am I able to go to an aftermarket 3 port one? (like grimspeed) Or will that just cause issues/run like crap?
Churr
Share this post
Link to post
Churr
If you're using a new controller then it doesn't matter what was there. You just need to setup the new controller to match the solenoid.
Share this post
Link to post
Is it just me or is Oamaru Starlet Gt capital.
Also- the turbo waste gate line, is that positive pressure line or vacuum as well?
Ta
Share this post
Link to post
i bought a sti radiator cap its rated for 1.3bar and my factory one is rated for 0.9bar will i have any issues?
eg hoses popping off?
Share this post
Link to post
I had an old radiator system that ended up splitting hoses from a higher pressure cap
Share this post
Link to post
owe no's its a proper sti one
should i avoid or just keep an eye on it?
Share this post
Link to post
If you have faith and wanna test your system chuck it on, keep an eye on it, if anything was to go wrong Itl happen within a week of driving or a few minutes of spirited driving lol.
If you didn't have any problems before generally speaking you "should" be ok.
Just do a quick read up of google with moving to a higher pressure cap etc
Share this post
Link to post
 paroxysm said:
Where does this nipple go to I can't remember
Putting my car back together and I can't remember where the one with the arrow runs to. Please help I'm stumped but it's probably extremely obvious...
Share this post
Link to post
DERP... right i found the right picture.
the largest one is for the BOV return.
The one close to the turbo inlet is for the header / crank case breather.
the very front long red one is IACV.
Share this post
Link to post
You see the long black hose that comes out of the intake pipe on the right and then goes under the manifold. I don't know where that goes to. I have connected bov return and everything else
Share this post
Link to post
The one thats not connected in this picture
Share this post
Link to post
yar! im searching! lol its the only one i cant trace!!
i know when i did mine i had that one blocked off. will be part of the head / crank case breather im sure. there is some t junction jiggerypockery under the manifold you cant see with it in place.
good 'dumb question'
Share this post
Link to post
winner winner chicken dinner. goes to the head / crank case breather system
Share this post
Link to post
Iphone 4s question....
Want to have the 'Find my iphone' app on my phone.
But to track and see the location of the iphone you need the 'location services' on.
Having the location services on.. will that cost me anything? It uses GPS correct?
Share this post
Link to post
it uses triangulation via wifi hotspots and cell towers. only uses data when you are runnung apps that use location services. you can also turn off which apps use location services, so only what you want to be running will be.
Share this post
Link to post
 kwi_fozze']
Have turned off everything which uses it... just want to make sure. Dont want to be paying a stupidly large bill at the end of the month lol
Share this post
Link to post
find my Iphone will use data( probably not alot) as it needs to send its location via Data
Share this post
Link to post
Im fine with it using data... but i though GPS used $$
Share this post
Link to post
 ADIKT']
GPS uses battery more than anything I thought. Maps can use alot of data though.
I'm not sure about the iPhone version but my app to find my Android only uses the GPS when required. I leave the GPS activated all the time and it only turns on when something like "find my phone" or GMaps requires it. It then goes back to standby when I stop using the app. I'd guess that iPhone's would do something similar?
Share this post
Link to post
 ADIKT']
nope GPS use is basically free to use for all of the world ( thanks US military)
Google Maps uses data as it downloads maps as you go ( or you can preload maps for a route before you leave, this is what I do)
I find that my Ipad uses heaps more data than my Galaxy s3 for doing the same stuff, have no idea why
Share this post
Link to post
I've preloaded maps for chch and wgtn - something like 30mb for the lot so nothing too strenuous. To activate the app though it will have to have a data connection at the time (won't it?) or it has no way to tell you where it is or that you want to find it (I guess)
New dumb question: LVV Certs - I remember a mate getting one ages back he had to go in with a failed WOF sheet first, then it passes cert, then it goes to now pass aforementioned WOF
Is this actually the case - I got a WOF last week and now have some adjustable struts to put in which I'll get certed asap - is there anything else I should know about at the same time? Not planning on doing anything more with the car
Share this post
Link to post
AFAIK you dont need to have it failed, you should be able to get it LVV at anytime for any reason.
Only suggestion I can make is that they DONOT put wheel size on the plate ( saves hassle later on)
Share this post
Link to post
    • Steve
      Does anyone else on here know or own one of the crouching tigers?
    • Matty t  »  gotasuby
      Help me please Hi iv fitted a dump valve to my vectra c 19 cdti 150 bhp. The 1 I bought was a twinport or receculation valve I don't no just bought and had a go of fitting it my self.  On looking at the car I thought I needed to block the 2nd port so have done bought a t and fitted it on the main intake Of The top Of The intercooler to the inlet on to Of The head.  Ran the bleed pipe and td it in to the on top Of The intake now it's just realeasing through the revs rather than when I lift of it's not because I blocked the other port is it thanks
    • WKDWRX
      https://www.instagram.com/p/BPPX4eLDujb/
    • Gordy Da Hori Hoon  »  RAYDEO
      Hi there,
      I paid online $20: for a 12 months ClubSub subscription.
      I am still waiting to receive:
      A Free ClubSub sticker A Welcome Letter & Membership Card A Discount Code for store items Can this be sorted, please.   Kind Regards,   Gordy Da Hori Hoon.     Hi Gordy Da Hori Hoon,
      Thank you for your order at ClubSUB - All We'll Drive. Your payment has been received and approved.
      — ClubSUB - All We'll Drive
        Order #86
      View Order
        Billing Address
      Gordon Samuels
      2/5 Arawa Street
      Papakura
      Auckland
      2110
        Payment Details
      Status  ✓ Approved
      Method  PayPal
      Transaction ID  3FY28950NY200842S
      Date  04/17/17 10:33 AM
      Amount  $20.00
        Order Details
       ItemTotal
      1 x 12 months$20.00
      Subtotal$20.00
      Total$20.00
