Dumb Question Thread!
Jambun
 clintondane said:
Vodka? Um no. I have no idea if you can clean them or not but if you were going to I\'d suggest an electrical contact cleaner, something like CRC MAF sensor cleaner etc.
Vodka would actually be fine. Isopropyl alcohol is cheaper though.
Sooooo I was casually driving home in the rain last night and it got me thinking. The rain was so heavy I couldn\'t see about 10-15 meters ahead of me. Should I be concerned about the amount of water that could of potentially got into the engine bay via the bonnet scoop?
I\'m sure the Subaru engineers took it into consideration when they designed the car, was just curious is all
 B4 2000']
[quote name='Timmah said:
When changing down, or even up a gear, there\'s a knocking type noise coming from the rear. Is the backlash from the rear diff?
my guess would be that rear diff mounts are rooted maybe?
Is there a simple way to check if the mounts are rooted? Neither sound good tbh.
i don\'t know how to test to be sure!
Maybe try raise the rear end and try moving hte diff front to rear/side to side? when mine were rooted i could tell by just looking at the mounts in the rear subframe as they weren\'t centered but rather sacked down!
now i have nolathane mounts!
Were they expensive?
your natural ramp rates will change a bit, and might affect your PID\'s if your link is capable and MAY net in some mild surge.
otherwise no for the most part if should go just fine.
abdul - yours is probably the most extreme gearbox change you can do in terms of overall gearing shift.
ya i know, im asking as i need to go back for a re-tune but don\'t know if i should wait till i change gbox or just do it now!
im still waiting on my diff and drive shaft to be here which is probably by the end of next week and im heading overseas the week after and won\'t be back till new years!
so tune now and gbox next week, or gbox next week and tune on hold till January!! hmm decision decision!!
box now, if the tune is going ok, and retune the lot after christmas... imo.
 QRAF said:
ok dumb Q whats the ratio of my nz new gearbox?
as i know i have a long rev range compared to a jap import, as when there changing gear i\'m still revving out.
how would we know that if you haven\'t provided your gearbox code
 funkytown']
will do
  • Guest locked this topic
