Dumb Question Thread!
Jambun
 evowrx said:
G4 dont run any form of knock control unless you buy the knocklink thing right? Only asking as Ive wripped the wire out of the knock plug will crimp to get it started if I have to.
I\'m fairly sure they do "listen" to the factory knock sensor.
 lachlan said:
id aim for 12.5 on full load
13.o on 0 boost
your timing sounds crude bu effective (ish)
your car is probobly richer that 10.0 but must things wont read it .
personally i wud say run 11.5 on full load
too risky running 12.5 on a suby
on no boost and vac run lamda 1 or higher
on spool richen that a bit but not too much
lean to spool turbo . dont argue
every tuner tunes anything for 12.5 on full power . subys are way lower com than most things anyway
na cars get tuned for 13.0 under full power which is atmospheric pressure in intake manifold so when your boost gauge passes 0 you want 13.0 to
you must know EVERY TUNER to make those comments
and lean my spool quicker but may also end up with less torque over all.
many tuners use many different methods
this is the dumb question thread not the dumb answer thread ;D ;D ;D
pretty sure your wrong wouldnt take everything you read as gospel
I would like to see you run 12.5afr on a methanol or e85 fuelled car :D. That\'s too lean on gas once you get to proper boost levels. And on a turbo car you want leaner than 13:1 at atmosphere as it has backpressure, something a non turbo does have as much of.
 Marky said:
Remember boys, Ping means Powah
Question: Best fix for squeaky swaybar bushes?
grease those puppies up :) plus i\'ve found the sway bar lock out clamps stop the bar shooting all over the place and the grease escapes quicker.
lock out clamps are about $20 a set (fo about $40 for f + r)
yea i meant richen from lamda1 for spool
as lamda1 is asking for trouble for spool
seem some suby cars running 12.5 but too risky e.g. bad fuel or something can push it into knock very fast hence y i prefer 11.5 max (bit less on power but still safe). i personally only tune to 11.1 on load anyway
  • Guest locked this topic
