come on guys lets see ur bays
mr.fix.it
  • Replies 297
  • Created
  • Last Reply
Top Posters In This Topic
wheres the air filter go? and why is there 3 hose clamps near the inlet mani?
Tight squeeze from that turbo outlet to bonnet?
I don't think it looks that messy, just the blue make them stand out more.
id switch that earthing kit with a black to try make it blend in or/and something like this http://www.trademe.co.nz/computers/cables-adaptors/other/auction-413456544.htm
Also i wouldn't run the boost gauge line off another one (not one as important as that anyway). meant to have there own
 mr.fix.it']
in response to this and the comments hes getting - its pretty gay if u diss someones hard work - shows jellousy - jelly is ugly !!!
and in response to this
[quote name='sti8u said:
+1 you can run if from the map sensor line.whch will be fine
if you know what ya looking at - it is teed into the map sensor line !!!
realistically speaking u dont want it tee'd into the map sensor - the map sensor be very important - teeing into it is only going to vary the signal it sends to the ecu - the map should have its own line
