flipping the manifold
off2harrys
negative..actually bought it off a guy from vegas who had it for about 4 years..
Was all forgd out and had a big garret of some sort before brad bought ,twisted turbo, flipped mani, possum link, forged out, wastegate etc, complete with cut springs haha
  • Replies 94
I'll have a closer inspection, my tank had always been in that position since I purchased it many a year ago. My mechanic Tony at RDL performance also flipped it for me, so I'll give him a buzz on tuesday on his exact methods with this one when I get my car back from tuning.
  • 8 months later...
 5UBZRO said:
i did a straight flip with my v3 manifold and put x2 sets of the gizzmo phenolic gaskets which lifts the manifold 6mm so as to clear the p/s reservior and prevents heat soak through to the manifold. just cut a few bits off the alloy alt/air con bracket and flip the alternator straight over to where the a/c pump was, then all you have to do is make a small adjuster bracket for it. a good time to do a parrallel fuel set-up while you are at it. by doing that and flipping the fmic so that the inlets are up the top i shortened a huge amount of pipework out of the car. you will need a new 5pk1105 belt if running standard pulleys or i my case a 5pk1045 if running gfb pulleys.
flipped my alt today.....i tried the 5pk1105 belt with standard pulleys and it was too small ???, ended up using belt # 5pk1220.....
  • 9 months later...
Hi funkytown unsure what your meaning, are you saying if I have a twin parrellal setup I can use single turbo ecu's?
Might have been reading between lines or just getting over Monday blues and not reading it right :(
yes if both turbos are the same and running identical boost then as far as the ecu is concerned it just boost.
same as having a single turbo really
  • 1 year later...
was wondering with a v3/4 intake manifold that has been cut and welded instead of flipping are there any other things u need to change i know the alternator has to be moved and a pulley put in place for the belt.
also does anyone have any better pictures of the front facing setup need to sort out how to do the alternator bracket etc.
  • 9 months later...
