any1 know how to tune possum link
TYP3RA
 TYP3RA said:
i have the controller i want it tune to run yellows and big turbo 3inch frontmount etc i wiped the original tune that it came with and now run s*** like with the standard ecu runs rich and idles jumpy??
wanna sell your controler ???
mate no need for your comments if i run a bearing i wont cry ill just build the bottom end haha just cause you cry when you blow yours dosent mean i will if you dont know how to tune bro keep your comments to yourself im not on here to get told something i already know cheers anyway
Do it urself man
Just do it really slowwwww
One small change at a time
Have a knock sensor and afr sensor to guide u along and logs will help
If u willing to do it slowly u can get it sussed
I started off with 165kw and now am at 235kw
But took a while to get here in very small small small steps and lots of learning along the way
Much more satisfaction on each small step
Ps. This is just a thot and only to be attempted if u know a little bit abt the tune side of things and prepared to read and learn a lot
yea bro im a fast learner but not to sure on the tuning side its the fuel that plays with my head lol any of you boys tune i dont want it fast i just want it runing smooth till i finish my motor build then will take it to a shop
 TYP3RA said:
and the reason why i dont get a proper tune is cause im like your user name!
then leave it standard.
he seems to have a lot time on his hand and like to do things himself or at cost...
rebuilding a bottom end probably cost as much as a tune doing it cheaply using 2nd hand parts, but then a 2nd hand engine is cheap enough but u dont learn anything if u alway let someone else doing it for you
good luck
yeah ended up cost more in the long run. maybe pappu can help him with the tune? hes here asking if anyone can do it cheaply not asking for advice... some people just need the advice? ???
i know its better if you take it in and tune bro but just wanted it tuned to run for now ill be finishing my motor tonyt wit xmas and new years out the way plus gotta rs to run around on now so can strip my ra and build again!!!
