FMIC Legalness?
i run a FMIC, and have not had any issue at all. having said that i have an RA with no airbags which i think may give you problems. from memory (i did this mod years ago) i dont think i had to cut much if anything... there was a piece i had to give a tap tho
  • 1 year later...
Yeah I\'m bringing this up again
Heaps of posts about it on CS, all are old, and all say "YES" "No"... "maybe?"
Does anyone know what the go is - is it "cert if metal cut" - or if bumper cut - or just if it affects airbag sensors - or just a blanket rule
When referring to "metal cut" is that meaning the steel flimsy bumper brace thing or just when people cut away bodywork to shorten pipes
I\'ve never had an issue with fitting larger ones to cars with FMIC from factory - just wondering since there\'s obviously enough kits being sold online which never seem to mention it - you\'d think they would if they\'d had feedback about it?
The whole cert thing is up in the air. Post 98- there is a higher threshold according to the cert boy mine was built in dec 98 for kicks but registered in Jan 99 - awkward. Pretty much he said by law you cant cut anything remotely structural or supporting structure and pretty much the whole front end is tapu including the bumper support bar. Cutting out the piece beside the guard where the snorkel comes through is ok. I trimmed down the bottom behind my bumper and wheel well so it all sat nice and wasnt a WOF issue. Stupid tho all depends on the cert guy some have been passed which are cleary structural I mean look at josephstefs one that passed no problem... :-\ With a bit of :o and a bit of :-* and you might get ;D .
TL:DR Talk to the guy thats certing your car - hes the only one with the deciding powar.
Mine flies through wof\'s. But I could get probably pulled up any time and pinged for a whole heap of stuff my wof guy doesn\'t care about.
Getting the wof is up to your wof guy and getting the ticket is up to the man with the flashing lights on his roof.
Would the cert man try to claim it needs certed to make hinself a job or would he avoid it to save himself a job?
 lachlan said:
anything with airbag needs cert for fmic . lotta gay rules around air bag stuff .
cant change seats etc
Wat?
You can change seats, only issue is if the car has the weight sensors in the seats that disable the airbag when nobody is in it.
 boon']
Wat?
this is not what i got told . got pulled up at an event also .... fella said weres the cert plate lucky he didn\'t look under the bonnet :D
 boon']
Wat?
Incorrect.
Any seat change (including factory seats, but from a diferent model) changes seating position and under nz\'s cert regulations, it requires certification. However, it takes a cop who knows what standard seats were in what to pick it up
as an example
Can I fit my Lancer GSR RS with a pair of Recaro race seats out of an Evo rally car? The seats are the FIA-approved SPG model and were fitted to Recaro rails which have bolted directly into my GSR.
Sounds like some confusion there. You can have your Recaro seats (yes, certainly a reputable brand!) without the need for a LVV cert provided that:
they\'ve been bolted in to unmodified seat anchorages;
that the anchorage or operation of the seatbelts are not affected;
that the belts are still correctly located in relation to your hip and shoulder;
and that you have no airbag.
The \'unmodified OE anchorages\' mean the mounts in the floor to which your rails or sliders bolt to - but I have heard of some WoF inspectors thinking \'anchorages\' means the rails
from here http://www.lvvta.org.nz/knowledge_base.html
Ok so that makes 95% of the seat swaps you see in scoobydoos not legal without cert (like WRX seats into legacy / forester / earlier model) - interesting (also common would be evo seats into legnum/galant etc for example?)
Bummer
Front mount was just asking about as tossing up if I was getting a WOF before mounting mine or if best to wait till I\'m getting cert etc - will be certing car once i get new adjustumbles (and by the looks of it, now seats too) so might just wait till then, better safe than sorry
ACTUALLY
- whats the go with replacing the bumper on a late model car as well then? Plenty of examples of people putting on the old c-west rep or whatever front bars onto B4\'s, V7 on etc - technically no different to hacking up stocker
Hrmm
Its a very grey area. Had cops check my forester with the sti impreza seats in, no issues. Think theres a tolerence for seat swaps of same / similar model, while not technically legit i believe as long as you arnt putting obviously aftermarket fixed back buckets in they\'ll let it slide. I mean, you get the same issue of passenger - airbag position with adjustble angle steering wheels aye?
Bummer
ACTUALLY
Hrmm
Run the FMIC normally round the sides then cert then make it what you want. I was planning on it but might not bother.
  • 1 year later...
I had to remove my fmic for a wof coz of airbag. Coz car was going for cert anyway i made a few phone calls and found out i could remove my airbag if car was older then 14 years. Had to change steering wheel and make a new button for horn etc and remove airbag bulb from behind dash.
