01 Legacy RSK AFM & O2 Sensor
sushi2hot4u
Hi guys, so my cars decided to go into Limp home mode yesterday and has check engine light on which puts out code 23 (ie. Air flow sensor Problem)
Quick question - does anyone know how much should an Air flow sensor and O2 Sensor for a BE5 Legacy RSK should cost? Any advice on where to get one from at good price in wellington area?
Thanks ;D
Thanks ;D Found one from subaru dealer for $200 bit pricey but atleast it will be genuine.
Have a quick inquiry, do you need to remove the battery before installing new one of these? Or can you just install it without removing battery and car detects a new sensor automatically?
Thanks again ;D
 funkytown said:
you dont need to undo the battery, but you will want to reset your ecu (plugs under the dash) after installing the new sensor.
My mechanic quoted me $300 for AF sensor and dealer has it for $200 even if it is more expensive than retail. I dont like putting in used parts unless I absolutely have to so trade me isn't an option.
By plugs i'm guessing you mean the black ones under the dash as opposed to the green ones which are for self diagnostic right?
