Sign in to follow this
canty_rex
turbo stutter?????
Hi all,
I have searched through and cannot seem to find an answer to my question so Ill ask it.
The other week doing some open road travel in my 1999 wrx I was passing starting at around 95km 2500rpm 5gear and speeding up and the turbo seemed to stutter I watched the boost gauge when I went to pass again same circumstances and it did it again and the boost drooped and rose again when it stuttered ( I dont know whether its the right word but it seems to fit). It did smooth out but it was weird. I had to for the drive back run 95 when I usually run98 dont know if that has anything to do with it. I cant remember if it did it on the way down tho I dont think it did. Havnt tested it recently to see if it does it again now im back on 98.
Share this post
Link to post
Just sounds like a miss, the change of gas may have caused it. When was the last time you did plugs?
Share this post
Link to post
I got the car 6 - 7 months ago the enginge has just ticked over 23 thou so never been done I gues since the engine replacement
Share this post
Link to post
the thing is did the car jerk and loose power as it stuttered - or was the car going as normal and stuttered
diference is the 1st one would seem like spark blow out - second would seem like compressor surge
Share this post
Link to post
more likely to be a failing coil/spark plug, although at kms that low you wouldnt expect that, check spark plugs are gapped, could also be a vacuum leak, unless youve got the boost wound right up but it doesnt sound like boost cut
Share this post
Link to post
i asked if the car hesitated / jerked - that would indicate a missfire (spark blowout)
boost cut does exactly that - cuts the injectors off
if it is stuttering and the car is still pulling and not jerking / hesitating (just boost fluctuating) it seems more directed at compressor surge
its fairly easy to get compressor surge out of a VF with high load / low revs
Share this post
Link to post
boost wont fluctuate with knock tho
he said his boost went up and down etc
best thing - take a video of it
Share this post
Link to post
i would get compressor surge around a bar in higher gears with low revs on part throttle
take a video of it that will explain it surely
Share this post
Link to post
nah compressor surge on throttle is nothing to do with bov
if it is surging on throttle- in laymans terms - the turbo is giving too much air - so much the engine cant use all of it so it comes back out the intake
bout as basic as i can put it
it might not be compressor surging - but normally if u stand on the gas in lower gears and its fine - and at low revs in higher gears u get it - it could well be compressor surge
bovs that are tightened will cause off throttle compressor surge - not on throttle
Share this post
Link to post
2500rpm in 5th with a reasonably flowy turbo is bound to cause surge if you get your foot up it. I get surge in 3rd-6th if I just bury it at low rpm.
Share this post
Link to post
If it is compressor surge - dont keep doing it - compressor wheels don't like it haha nore do the bearings
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
