Marky
The "Hose 10" Mod - BE/BH
10 hours ago, gunit439 said:
Sorry, how do I tell if I have a rev-d or if it is gen 3?, I do see a "T" at the end of the hose coming off the bov though, I tried taking it off and blocking both sides, went for a drive and it did not seem to change anything at all?. Will take a pic and post it in the morning, maybe that may clear things up a bit.
its 2001 so most likely a Rev-D, what is the model code on the vin plate,you mentioned TA-BE5, on that same plate look down for the model should start with BE5D, also Rev-D has different headlights and other changes like pink top feed injectors etc.
Visually standing and looking at the car the easiest way to tell the difference is the headlights.
Rev-D
  Image result for 2000 legacy headlight
Rev- A B C
Image result for 1999 legacy BE headlight
Edited by A_J_T
Share this post
Link to post
I have photos of it but I don't know how to upload them here?, how did you upload your pics?. Also yeah I am sure its a Rev-D as the indicator is the same as in the pics.
Share this post
Link to post
Thanks, I have uploaded some pics of my car and setup, I would still like to try this mod and see if I get any results.16114795_1775987142726947_6154253462946815978007_1775987196060275_7481192538490316114382_1775987166060278_6213786904529816105678_1775987229393605_27718782190653
If you can see in the pics, I seem to have 2 "Ts" coming off the bov, don't know if this is normal or not?. I have found the number 10 hose connected to another "T" which connects to turbo, not sure if you can make it out in the pic.
Share this post
Link to post
Looks like someone has switched your intercooler and bov set up for a gen 2 set up. But the small hose between the two tee's is the one you want to remove and blank off the tee's.
Share this post
Link to post
Agreed, looks odd for a rev-D.. someone has already been there and played around. @gunit439 but yea the short length of black hose between the T just kink it and tie it with a zip tie. go for a drive, then revert if it does nothing.
Share this post
Link to post
Thanks for the suggestions and help, I just removed the hose between the 2 Ts and blocked both ends, went for a drive and it did not seem to change anything?, I already have a boost gauge installed and was hitting 11-12 psi as usual and about the same after vod. Maybe like someone else suggested, it has minimal to no effect on some rev-d setups?, is there anything I need to do with the hose 10 line as I see there is a T connected to that too?
Share this post
Link to post
@Kiwi_Fozze DO YOU KNOW WHO I AM
Also by way of follow up
My previous two Rev D legacies both had the revised hose arrangement - meaning no "hose 10 mod" to be done, they had a direct line from manifold to BOV from factory
I have a Rev C (backlit dash, new interior, old headlights and ECU setup) at the moment which been done, runs 15psi primary by 2400rpm and about 20psi on secondary (there may be another issue here) - it ran about 10 / 14psi before
Some rev D apparently do not have a revised hose arrangement? I am confuse by this - I get the feeling there's some confusion re what hoses are even being talked about
Share this post
Link to post
Rev d should all have direct line...
And if it does have direct line, its probably the best spot to tee a gauge in to. Because all the other pressure / vac lines have sensitive stuff plugged into the other end of it
Share this post
Link to post
Yeah exactly - I don't know what hose the half dozen owners who are saying they've done stuff on a rev D have done to be honest
And yes agreed re where to plug in the hose - that fulla on the bookface I get the feeling is not too mechanical so didn't want to over complicate it
Share this post
Link to post
Thread revival! Can this be done with the VDC twin port bov? The hose setup on that looks quite different to the photos that are still working on this thread...
Share this post
Link to post
Tried this tonight and went to 5psi on both before and after vod, maybe not possible on the twin port vdc bov...
Edited by k1w1
Share this post
Link to post
So what do i do with hose going to intake pipe? Block it i assume? Does standard hose from manifold to bov have pill in it? If so do i just replace hose with straight vac hose. Churr
Share this post
Link to post
On 1/9/2013 at 0:03 PM, Marky said:
Yep
Just remove the tee-d off hose, put a straight pipe from mani to BOV (as per any other car), and from memory down at the inlet pipe there\'s a plastic T for the hose you removed and 10 to both join to the inlet pipe - just whip that out and put 10 straight onto the inlet instead
Can I do this mod/is there a point if I have a manual boost controller on the primary turbo?
Share this post
Link to post
having a boost tap on these is a sure fire way to over boost the (very small) turbos. I'd remove the boost tap and do this.
The two turbos share the same wastegate, its a pretty complex setup. Many peopel refer to it as wizardry.
have a read through this:
Share this post
Link to post
Does a boost tap make both turbo run on the same psi?
Share this post
Link to post
Sorry old thread drag up! - I looked at doing this mod to my BE5 i noticed the hose between the two tees that you remove has a restrictor pill in it should this pill be there?
Share this post
Link to post
Hose 10 mod isn't applicable on the Revision D as far as I know :)
Share this post
Link to post
Hmm that's very confusing then as it would appear after reading through all 10 pages in this thread that people with Rev D have done it...
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
