headunit issues
BlueTeamRacing
Don\'t use the aerial as the ground. If your existing wiring doesn\'t have an earth wire, attach it to a metal part of the car.
Also, check the fuses in the engine bay. The interior fuse may be blown.
But definitely make sure you are using the correct wire for the constant +12v and the switched +12v. This will be what is causing your memory issues.
+1 swap em round and with the fuse replaced it should go. Easy way to check if you have a multimeter or test light is with the key off the yellow wire should have ~12v(multimeter) or the testlight should light up with the key on or off, that will be the batt wire which will let you keep your settings. Repeat same with the red but when key is off there should be 0v/no light, thats the acc. Hope you sort it
This
also, check your fuses
 Codex']
[quote name='Timmah said:
What car is this for? And head unit? I could swing by one day next week and compare wiring.
For a friends gen 1 legacy, jvc unit. For some reason the constant 12 isn\'t constant and can\'t work out why.
Are their speaker wiring the same as the WRX\'s? My head unit is Pioneer though :S
