headunit issues
BlueTeamRacing
 newsuba']
Why not wire it through the ignition like a normal install ?
So key off, stereo off.
Unfortunately I didn\'t do the original installation :/ not sure who did it. It was working fine using the original loom then apparently one day the headunit either slid out and stopped working or something similar. It works with key on, turns off with key off but without the constant it doesn\'t save anything.
[quote name='kwi_fozze said:
I think the issue is an undertaking of electrical work without a correct tester... Get a $20 multimeter from dse or repco or similar, and wire it properly... Will save you a buggered battery...
Yeah that\'s the plan, I have a volt metre already so will use that and borrow a friends tracing wand to find where the break is.
Assuming I can get to it before he sells up before going to aus >_<
blkrex you need to rewire the power. Each head unit will have 2 power wires, one goes to battery and the other to ignition(one for mem or clock the other for complete power)
So you need one wire which is straight to battery so it keeps mem and time ect (sounds like you might already have this wired to the one that should be wired to ignition so do a switch of those 2 wires)
Then the other power wire has to go to an ignition source (easiest would be cig light just splice onto the power side of it)
atm it sounds like you\'ve got half of it correct but if the unit is staying on you\'ve wired it to batter and need to wire to an ignition source instead. Easy way to tell which is which is to go buy 20$ multimeter attached to a ground and then a source you think is power. Check with key out of ignition then again with key in an all power turned on ready to crank. Your looking for a wire that only turns on with the ignition. Or just do the cheapo diyer way and attach it to something else that comes on with ignition like cig lighter or maybe a gauge or something you have in car? Hoping you\'ve got the instructions so it tells you which power wire is which haha otherwise trial and error
hope that makes sense. I \'m in woolston if you are really struggling
