turbo's
fish1963
 fish1963 said:
what is the difference between these turbo\'s?
vf13 vf14,vf16 vf17,vf18 vf19?
These are what I call the series 1 (Ball Bearing) turbos with addition of the VF20/21.
The pairing sets VF13/VF14,VF16/17,VF18/19 and VF20/21
Primary turbos VF13w/16w/18W/20W
Secondary turbos VF14W/17W/19/21
w=wastegate with small actuator
W=wastegate with large actuator
Primary:Peak Flow or max CFM VF18>VF20=VF16>>VF13
Secondary: Peak Flow or max CFM VF19>VF21=VF17=VF14
The CFM is based on comparing the Compressor wheel size/trim in combination with turbine wheel (4600I vs 5700I) used and turbine A/R or P
