can I turn a gf8 Wrx (turbo) to sti eg ecu ,airflow meter,440cc injectors?
chopper69
  • Replies 112
short answer another words is YES
but there are risks : INTERNALS
make sure you see that part and think about it
not saying its a bad idea just beware, things like boost levels and compression ratio\'s come into factor here
also consider a fuel pump up grade at same time perhaps? (possible \'parrellel" fuel line upgrade also)
Funky : make sure you yell at me if I am spreading dolphin\'ism\'s [\'cos I am JUST a Legacy man who has never physically done any of this apart from swapp motors and fuel pumps)
I was thinking about doing this on my V3 GF8 before it got stolen haha
I found out that all you needed was Orange AFM, Yellow Injectors, Vf23 or similar and ECU from the corresponding STI. Plus maybe some minor wiring changes. You should have the EJ20G which has stood up to 260-275hp on previous models so it should be fine.
Here is a guide to Subaru ECUs so you can work out which ECU you need:
http://sdrv.ms/12WGLVE
Of course this is all in theory and in practice its probably going to be a small mission..
Ive done it, and yes its as simple as unbolting/unplugging everything lol no wiring needed
 greatdanz']
url=http://sdrv.ms/12WGLVE]http://sdrv.ms/12WGLVE[/url]
There you go! Go for it!
Although if you look at the chassis number it looks like it might be the oddball EJ205:
http://pacificcoastjdm.com/review/subaru/imprezagc8/stats
you can use a 1S from JDM V3 WRX ecu which is tuned and matched to a VF22,orange AFM, yellows. and rated @206kw factory. or you can use a 6S from a V3 STi which i believe has a more mild tune
I used the "75" ecu from a V4 STI RA which has a nice factory aggressive tune when I did my conversion
 greatdanz said:
air intake sensor? before or after the AFM? more likely to be aftermarket, mine didnt have one so didnt need one.
you shouldnt have to remove/touch the plugs to the crank/cam senors as they should be the same on both engines
Some did have it funky or sl8r can tell you more about it.
The purple afm is screaming check the car more carefully.... i suspect it will hwve the oddball ej205..
If normal wrx i would have expected green..
What revision wrx as per my first request OP...?
Ah i see its an F... thats v5..
So 1s / 3s / 4s all wont work...
GF8s had the same set up as the foz from the time Purple AFM, td04 and grey injectors.
No such thing as 8s ECU i would think you have an 88 (or 8z if automatic) ECU as its OBD 2 compliant being an 98 model car, The STI version of this is the 75.
Could use 1s or 6s but may (or may not) require wiring changes and car would no longer be OBD 2 compliant.
. the ecus normally used and described above all wont work without changng the wiring
Im not a v5/6 expert but pretty sure you will have a higher CR motor so will be problomatic to put in sti ecu in.
It has been talked about else where before. Im pretty sure gazzy2000 has more concrete info on this type of sti conversion
