boost vac lines setup on v3/4
tydon
running 2 port boost solenoid.
how should i have my boost lines hooked up i have wastegate and turbo nipple tee\'d off going to the middle port on boost soelnoid.
the bottom port on boost solenoid is going to intake pipe .
Map sensor going to manifold nipple.
only getting around 0.7 bar.
Subaru in greenlane/auckland sell them
Not sure how much,people just tend to make them,
There are hory ways too do it but wouldnt advise doing it
Such as using a 3 way plastic tee piece and hooking up the turbo side and other on the actuater and leave the other one bleeding off,trick is to use a lighter and burn the size of the hole that is bleeding air smaller to your desired boost,it does work and holds boost fine from what iv seen,i guess its a 2$ boost tap they both do the same thing haha
But as i said wouldnt advise it and is abit hory haha. 😂
On my car (v3 sti) a 0.9mm restrictor pill gives me 18psi and drops to 16psi after 6k.
Have tried 0.8 and 1mm too, 0.8 gave me 19/20psi but seeed to drop back further to 14/15psi, felt slower. 1mm if I remember right gave me just over 10psi.
Boost with solenoid is laggier, get a cheap boost tap and be relatively smart with it :)
