Boost Plumbing v2
tydon
  • Replies 54
  • Created
  • Last Reply
Top Posters In This Topic
I give mine a gentle wire brush or slide a piece of wet & dry through the gap, then spray with WD40 and wipe with a rag.
A plastic bread tag is 0.8mm, check your gaps with one. But chances are your plugs aren\'t the issue so they will foul again.
AFM dodgy or bung coil packs?
yeah green afm label.
got boost gauge in its runing 10psi but sometimes it hits 12psi and 11psi lol.
apparently they replaced 1 coil before i got and now ive replaced one and they all looked reasonably good when i changed plugs
vaccums -11 on idle -13 on deceleration
lol soo some search brought me to -20hg roughly is wat it should idle at on vac.
and converting -10psi to hg is -20hg so sounds about right.
sooo i needa try another Afm and check plugs again and re check coils as one may of gone sour on me hopefully not the case
 Leufkax said:
If you don\'t even know how to gap plugs you shouldn\'t be fucking with cars
i think ive done pretty well considering ive done three twinturbo to singleturbo conversions all the mechanical work .
all the rewiring myself mulitple engine transplants and clutch replacements and had no issues after doing the work myself.
look through my posts and you\'ll see the projects ive done.
not a mechanic but ive done well for being self taught with good advice from members on here
thanks roo yeah 2 years ago all i knew about cars was you put petrol in them haha.
now i love working on subarus and thanks to a whole bunch o guys on here i wouldnt have been able to do the things ive done and learnt the things i have.
you guys are legends! haha
Also a big learning curve in the world of swearing thrown in there amongst the blood and tears.
Couple of years ago I was never gonna own a sub but hell theyre pretty awesome in their own right when you get into them and pretty damn easy to work on imo.
