Dunedin Subaru owner.
nivaman
Hi
I have bought a 1995 Subaru Legacy with a EJ22E engine.
This engine has over heated and i am going to replace the head gaskets.
The engine still runs but when the engine is started it sounds like it is lacking compression, there is no oil in the water but there is a slight milky sludge in the radiator filler neck.
When the radiator cap is taken off and the engine is started, there is a geyser of coolant coming from the radiator, the engine has no knocks or smoke and the oil pressure is ok.
I was going to replace the engine but cannot seem to find another EJ22E engine for love nor money so have bought a top end rebuild kit.
Are these engines a strong engine?, can i fit the gasket set (after checking heads/block for flat, machining etc) and call it done?.
I need to get the vehicle down to Dunedin from Alexandra, is there anyone who i could borrow a car trailer or get it down by a truck back load for minimal cost or beer tokens?, i also have 4 tires and rims i need to get from Queenstown.
Many thanks.
I would be getting the radiator cleaned out while your at it or at least looking into why it overheated in the first place. Get the heads machined/resurfaced. Also best to get them crack tested (may have a crack between coolant jacket and cylinder) and hardness tested. Not entirely sure how strong ... I know the EJ25 don\'t like getting hot but sorry not sure about the EJ22.
Replace the thermostat with genuine Subaru item (aftermarket thermostats can be a bit temperamental) and make sure the heads a torqued down to the right settings and are torqued in the correct order.
If you are careful and get advice from the right places you should be ok. Have you done headgaskets before because it is quite an undertaking, especially on a Subaru.
and I can\'t help with trailer sorry ....
