update on my build bc5 2.2
bc5rs
ok just a reminder ive got
a bc5 rs-d according to the tags
no abs or anything fancy
td05
tuned manifold
440cc injectors
bosch external with surge tank attached
micotech lt8s pluged into factory loom
ra front and rear seats
240km speedo
ra box rather close ratios
ssr type c rims
4 pot fronts
lowered just springs
before the mods it did a 13.9 on the quarter mile
1evlrs
rayburg spotlights hid
v3-4 scoop not sure which
still got the waic but thatl change
building a 2.2 flipped manifold front mount ect
clean silver body with the we lip on the kit
at the track day i blew some ring lans thanks to a bad lift pump
so my 2.2 build is now underway
i have my 2.2 block good clean one no damage
crank ,using the crank from my cdb
rods i am buying from a freind after i strip his engines for him
pistons anr only 600 landed from the state
bearings are local as luqifaction
and caraid have my heads gtb ,and will bolt them on for me after reseating etc
im getting a alloy rad but its going to be 3inch shorter so allow the cooler pipes to go over it ( i dont want tocut my chassis)
flipped manifold 550cc injectors from another mate and then i havent decided on turbo yet td06 or something of the like
anywho just thought i should write it down what i was up to ,
body wise changing front lower arms and suspention to adjusties maybe some underbody bracing aswell but engine is the item on the go at the moment
