2001 be5 oxygen sensor help
b4legacy
I\'ve recently had my engine check light come on so i got a friend to check the codes. It comes up oxygen sensor that\'s fine my problem is my car has a front and back one is there anyway to tell which one it is? my mate didn\'t know or are they the same?? try\'d searching couldn\'t any info any help is appreciated.
It will probably be the front one. The code may not mean the O2 sensor is crook though. There may have been a misfire, or the sensor got drowned in a puddle of water and got too cold to read correctly, and so the code gets set.
The trouble codes are only indicators, they always need checking against the circumstances and diagnosis carefully.
If you use two regular sewing pins or needles you can back probe the connector plug of the O2 sensor and then use a volt gauge to test the sensor while the car is running.. or, connect a laptop or scanner and read what the O2 sensor is doing while the car is running.
 Rosssub said:
There should be a different code for each sensor if there\'s 2. i.e:
P0136 O2 Bank 1 Sensor 2
P0131 O2 Bank 1 Sensor 1
Are you sure ones not a Cat temp sensor or something else?
when we got it checked all i can remember coming up was heater sensor or something on the computer, we cleared it then it came back on again while the car was running. this was done by a auto electrican, he couldnt tell me which one it was. theres one on the downpipe for the 2nd or 1st turbo and one just before the cat from what i remember
I would re-check codes to make sure, but yip That\'ll be it.
Edit: That\'s for CEL code 31. The rear O2 Sensor should be CEL code 36 which is post Cat. An A/F reading too far apart between these 2 Sensors will trip another CEL again (Maybe an Air/Fuel Ratio CEL or Cat Fault CEL).
Editit: Thinking about it the Rear O2 Sensor might be in your Exhaust Y pipe where both Down Pipes meet (Rev C/D. I only have one O2 AFAIK (Rev B).
