Ask your tuning questions here!
gotasuby
 Rosssub']
[quote name='gotasuby said:
Yes. With AVCS you get a different ve at low rpm so your feeling will be weird. Make sure you change trigger patterns to early type though.
Mint. 8) Will do. ;)
When you\'re finished with the J2 and onto the link, wanna sell it to me?
The voices in my head told me to...
 94 Leone']
Maybe, ;D Could be 4-6 months away though?
  • 4 weeks later...
Have tuned my car afr wise at the moment but still running v6 base ignition timing until I can sort something out to measure knock. Just came across this though http://www.instructables.com/id/Use-Your-Laptop-as-Oscilloscope/ and was thinking, would it not be an accurate way of measuring knock for like $20..? I dont know, your guys thoughts? Seems like any accurate knock detection equipment costs moonbeams!
I do and don\'t get where you are coming from.. With a decent oscilloscope program will i not be able to do exactly what the knock block does to analyse knock? I.e take a base runs across different frequencies, take a frequency that is measuring the most noise and use that to make a base line for engine noise. Then as I increase the advance I will be able to see areas that differ from the base line curve that had no knock? The only downside I can see from using this is that I will not have on the fly knock control happening via the ECU as it has no idea if it is detonating or not.
G1 possum link question for ya gotasuby,
I have got a seriallink now, had a wee look and all the sensors seem to be behaving although i haven't taken it for a blat to load it up, but i was wondering if i could start logging on the ECU then come back and download it, or do i have to leave a PC attached for logging?
Hey bud I know Danny said a while ago he was running d/c to get a single stage water/meth unit to work across rev range but how do you set up the map for that? Got everything bar the pump so cross that bridge when I get to it just dont want to run a proper controller. Would be a single nozzle pre TB.
