Fitting cruise control
richnorm
  • 8 months later...
 seith_31 said:
yeah sohc legacy. subaru might have different looms for the base model legacy's
Most likely that's the case, looks like higher spec GT and 3.0 all have the needed plug in place. I know 5th gen Legacies and 4th gen push start button 07+ models require a bit of wiring to do, not as straight forward as plug and play.
Shouldn't take long to find, mine was taped to the 3pin plug.
  • 11 months later...
1 hour ago, nickmcgill said:
Got all my bits, installed the buttons. Bought a 4 wire sensor after reading it needs one. Looks like the 07 isn't fitted with one on the loom. Damn.
Is yours push start? From what I've read it's still doable. Just a bit more involving as you need to run a few wires from ECU. Similar to 5th gens.
  • 5 weeks later...
2006 BP5 Legacy (facelift) 2.0 SOHC
Mod worked mint brought the steering wheel button assy new from Partsouq and the 4 wire brake switch from a local wrecker.
No dash lights but eco/sport light does turn off when in cruise.
Cheers heaps guys for the info.
  • Like 4
On 8/18/2014 at 10:07 PM, BP5Nut said:
Can confirm this works on pre-facelift gen 4 legacys. Installed it over the weekend on mine (2004 5spd turbo wagon). Cost me $92 for the switch & 4 pin brake switch from Strong's.
No lights on the dash, but works perfectly. Didn't do any updates or anything (that I could see anyway), just plugged in the switches and it worked.
Thanks for all the info in the thread - was a very painless process for me.
Need a different switch from the one shown in this thread for the pre-facelift cars though:
Reviving an old thread....Do you know what part number is the switch for pre-facelift? I see those with facelift BP/BL's used this (https://partsouq.com/en/search/search?q=83370AA001)
  • 7 months later...
18 minutes ago, k1w1 said:
Did anyone work out what to do to get this working if no 4 pin connector is available on a JDM 07 GT Legacy??
Don't know if anyone done it in NZ, been successfully done overseas - you need to run two missing wires from ECU, not a straightforward task.
Keep in mind that different ECU will have different pin-outs/colour code for wires. Finding a wiring diagram for your model will be a good start. ECU is located under passenger footwell.
Yes I do. I spent a lot of time figuring it out and finding correct manual etc. I'm willing to do to your car but it's unfair on my customer who had to pay me to research it all for me to make it easily publicly available. I have given enough info to make it pretty easy to do the leg work yourself.
30 minutes ago, k1w1 said:
Too easy mate that's fair enough what's your business called and what type of work do you do? Do you have a website?
Google is your best friend. All you really need is to find service manuals with wiring diagrams specific to your Legacy.
Similar to the ones shown below:
