Pod Filter
Venom
i'm looking into getting a pod filter for my WRX and seems that getting the pipe w/ AF sensor thing on it seems to be extremely pricey.
K&N kits are like $600. are there any cheaper ways to do this?
Fck all that
Chuck a pod on it, it sounds mean
Chuck a BOV on it, backfires are also mean
There are guys on here who will laugh at a pod filter then bolt a set of rally spec mudflaps to their daily driver street car, for me I get turbo cars over other fast options simply for the noise
Regarding your actual problem look locally for a pod filter adaptor to suit, www.subaruspeed.co.nz is a good place to look also. If you're just googling you'll end up with mostly U.S pricing and options, there are much cheaper alternatives in NZ. If it's a newer WRX (V7 onwards) the pipe shape & size is pretty generic
Like this
http://www.trademe.co.nz/motors/car-parts-accessories/subaru/engines/auction-732294229.htm
or this
http://www.trademe.co.nz/motors/car-parts-accessories/performance/air-filters/auction-732465111.htm
The one Loner linked to above is pretty good. Bolted right onto my v5 AFM and on the dyno showed it wasnt restrictive at all.
Although the wait from Fortyone was a bit long when I got mine.
Contaminated air must exit the exhaust pipe would prob be the tech explanation but "because its illegal" works for me. I run mine atmo but I arent gonna tell a cop to stick it up his arse if I get nailed as he would be correct to award a green sticker. I think going 120km in a 100km zone is perfectly safe but rules are rules.
picked up a BOV but for some reason its not loud in anyway what so ever. anyone know why that might be? plugged up the plumb back line, using the factory vacuum line. should i be running a different vacuum line?
lol My bov is full atmos dump and balls it the loudest bov you will ever hear if I loosen it right up. Get the cronic backfire now and then though between gear changes. - mine http://www.subaruspeed.co.nz/products/blow-off-valve-blitz-2
I have seen your bov on trademe and if it's not a blitz then its a blitz replicate thats for sure because right down to the color that is the exact same.
Edited by Zach
