legacy with boost problems
yellowsub
hey guys im after a little help
a little while ago i poped my bottom hose on my gtb as my inter cooler piping poped a hole in the hose
now i drove car home 4 hours later it was only a 3 min drive home now seance then im not able to boost over 10 pounds i have ebc to control my boost
i toke plugs out and they were white on tips so made a call that shes running lean i have replaced the fuel pump with walbro and have replaced the filter at same time
now the car is a bg5 converted to single turbo running vf30 flipped intake etc the plugs were replaced when the motor was rebuilt 40 k ago has anyone got anymore pointers what alse i can look for ( have also checked all vac lines and fuel lines for any damage aswell and came up with nothing
Yeah it should whack open with 12v applied. If it only seems to make a little tick sound, then try blasting some carby cleaner through it.
If it's the square aftermarket solenoid, you can also unscrew the top cover and clean up the internal electrics/contacts etc with some contact cleaner.
