Nith
2003 BP GT-B electrical questions
Just been looking at a few things since I have brought the car, my clock / trip computer doesn't work and just displays an ERR code. What I have found from searching the forum is that it can be just a dry solder joint, correct me if I am wrong. I will take apart and look soon.
If some one could please help me explain a few other things as well to clear some confusion!
I was looking in the Main fuse box and found the fuse for Main Fan was removed, I have since replace it. Any reason for this?
https://www.dropbox.com/s/0vwpr8i64jnekha/IMG_20141201_202715.jpg?dl=0
Also what the hell is this thing?
https://www.dropbox.com/s/pc31gq1jc7sj05q/IMG_20141201_202854.jpg?dl=0
Are these plugs for the fault code finding as well? Located on the floor near the bonnet latch
https://www.dropbox.com/s/1hg3u2a77cj60j4/IMG_20141201_202901.jpg?dl=0
Any help would be much appreciated :-)
Edited by Nith
Share this post
Link to post
Pictures don't work. And fuse is only for h6 is remember correctly. Check fuse box lid. Green plugs are reflashing and diagnostic plugs
Share this post
Link to post
Pictures working now? So the white and green plugs that are unplugged are for reflashing and diagnostic only?
Share this post
Link to post
 gotasuby said:
No still obviously only working if you logged on to Dropbox?
Stupid Dropbox... Will sort it tomorrow
Share this post
Link to post
From what i've read the BP/BLs have 2 sets of green connectors, both of which have to be plugged together to re-flash. One in the passenger footwell as well as the drivers?
Share this post
Link to post
From what i've read it varies between models/ years some need both others not.. Mine has been able to pull roms from ecu and flash back using just the one under the passenger side carpet. Pretty much right at the top right near the glovebox.
Also if its 07+ it'll most likely be a canbus ecu which doesn't need to have the connectors connected at all. According to romraider atleast. Haven't tried doing it with mine which i assume is canbus since it needs to run the canbus setting in ecuflash to work.
Edit: you could also say if mine is a canbus ecu then me plugging in one of the connectors might not be even doing anything for flashing and that its working because it doesn't need to have them connected at all.
I should probably look a bit deeper into this.....
Edited by Andy_Mac
Share this post
Link to post
white plugs are for reprogramming keys. green plugs are diagnostic. and reflash. both must be plugged in to reflash. they are in series. the handsfree thing maybe a radar jammer parts? bet you fuse isnt needed as its either 1 or other depedning on motor
Share this post
Link to post
So if they are in series then wouldn't you say that if you plug just one in then absolutly nothing would happen?
I know with mine if i do just the passenger one and turn the ign on it cycles the fans and does all the ticking and clicking and what not. So that would indicate its doing its diagnostic thing as it should without needing both. Comes up quite often on US based sites where they talk about only needing one set for flashing
Share this post
Link to post
You'll probably find that the ones on your drivers side are plugged in already, and your just using your passenger ones. When I found my passenger ones they were already plugged in.
Share this post
Link to post
This as when Subaru dealerships test the car when new they are lazy and only usually unplug 1 set
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
  • Similar Content
    • By rorygtb
      Hi all,
      Over from the UKLegacy forums as I know quite a lot of you kiwis and aussies and have the tt leggys too! Was wondering if someone can shed some light on an issue im having.
      Car has been running like sh1t- poor fuel economy, lumpy acceleration, lumpy on idle when started from hot, struggles to stay alive as the revs want to drop.
      Plugged in SSM cable and front o2 sensor voltage was reading 0.000v. Cleaned the plug... still nothing. Replaced the sensor with a bosch universal 3 wire and its still showing 0.000v. Jumps to about .02v for a split second when the throttle is pressed but instantly drops back to 0v.
      When I test the black signal wire at the plug where the sensor joins the loom, there is 0.45v at idle (this is about right as this would suggest a normal AFR). This suggests the sensor is working and reading accurately. At the ecu however, the voltage is different.
      Service manual says that at the ecu plug, the o2 should see between 2.3-2.8v (iirc) . At the ecu pin, mine showed 0.80v with the car idling and o2 sensor unplugged. When plugged in, it jumped to 1.1v but fluctuated massively (down to about 0.6v when revved in neutral and back up to 1+ but never as high as 2v+.
      I tested the pins on the loom-side plug on the car to see if they were getting power. The heater wire pin was easy to identify as it was getting a solid 12v. The other white was the ground but was still getting like 0.5v. The signal wire itself was also getting about 0.38v which I found a bit strange but I dont understand enough about auto electrics to make sense of it.
      I tried bypassing the entire wiring to see if it was a wiring fault but didnt make much headway. I ran pins from all 3 ports on the o2 sensor plug. The heating elements went straight to the battery positive and negative terminals to simulate the 12v and the ground. The signal wire was ran directly from the 02 plug inside the car and alligator clipped to a paperclip jammed in the back of the 02 signal wire at the ecu. On ssm it showed a constant .330v (usually what a broken o2 will show). It would not move despite revving the car and stank of fuel due to it telling the car its  was running a lean mix.
      Took it to a garage today and the lad was adamant that I should start with an oem sensor as universal ones are bad for subarus apparently. They dont agree with universal sensors etc. This wouldn't be an issue but the oem sensors are like £180/$250+ and im a student lol. Is there anything else I can try before buying one?
      This is the second universal bosch o2 inside 8 months, this is the reason Im worried it isnt the actual fault of the sensor. Im fairly confident there is something else weird going on with the ecu/wiring.
      Any help is much appreciated, thank you troops
    • By Leigh29
      Hello
      I own a Subaru Legacy B4 1999 automatic, today I took it to get a service and Wof. I was only aware that the car may fail the Wof as the rego lights were not working, 3hours later after waiting I was informed by the company that they had replaced both rego bulbs and had tested the fuses and they still did not work so i would need to go to an auto electrician as the mechanic believed it could be a wiring issue.Therefore the car failed the warrent. 10minutes later I paid up and jumped in my car, before I drive out onto the road I applied my brakes and heard the reversing sound, I checked to make sure I was in drive which I was yet I could still hear the beeping noise as if the car was in reverse.
      I drove back up to the company that had just serviced and completed a Wof check to ask if they had crossed wires or done something.
      Two mechanic's came out and I advised them that every time I apply my brakes I was hearing the reversing sound even when the car was in drive. One of the mechanics said it was serious electrical fault. I asked if this was related to the two back rego lights not working and he said it could be. I also advised that my car had never done that, the mechanic said ever when they tested it, it was not making the sound. So now I have two issues that need to be assessed by an auto electrician.
      It makes me wonder if the mechanic had caused the second issue of the "reversing beeping sound" when the brakes are applied or if it is just another problem to sort.
      The car went into the shop with 1 issue and came out with 2.
      Any feedback would be great.
      Thanks
