borland667
Newer ECU on older phase 1 engines
23 posts in this topic
Hey folks, anyone has a newer re-flashable ecu running on an old engine? Any ideas of what would have to be done to make that work? Cheers!
Share this post
Link to post
fuel, timing, ignition- crank sensors use different triggers; would require telling the computer to ignore avcs.
Do-able if someone knew their way around the computer.
I'll be following- cheap yet exceptionally time consuming alternative to aftermarket computer :P
Share this post
Link to post
Definitely my next project after I finish with the v3... and of course, I will post here first evowrx! LOL
Share this post
Link to post
Would be just quicker and easier to do a daughter board or a plugin link.......... dont see much a an advantage other than a technical exercise of can it be done...
Share this post
Link to post
Link are expensive this is quarter of the price with slightly more hassle. Providing you could get it working with early triggers. Even then its definitely doable just need to find cam gear and crank trigger wheel. Run carberry rom then no maf required.
Makes sense on v5/6. Just replace with late mani and tb then add v7 ecu with a plug in adaptor. Easy reflashable ecu for under 500 just need to be better with wiring than me.
Share this post
Link to post
You'd wanna change crank sprocket for that. Otherwise is a tempting mod haha
Share this post
Link to post
Easy enough if youre doing timing anyway. If not its not a biggie to whip belt off.
Share this post
Link to post
ESL daughter boards, very good upgrade with early standard ecu, fully mapable and does away with afm
Share this post
Link to post
Esl yes, but nothing yet for the v5/6. There are 3 methods for retunes on the 5 and 6....
1: link
2: tune in napier, costs about $1500, i forget who does them
3: later ecu swap
Share this post
Link to post
Wrc were 1k last check. Plus travel and he wanted it overnight so accom unless you know someone local.
Share this post
Link to post
Lol all good. Main point being although the v5/6 is a fantastic car, there is f**k all out there in regards to tuning options that doesnt cost an arm and a leg
Share this post
Link to post
ESL Daughterboards are supposed to be coming in later this year for v5/6 no?
Share this post
Link to post
But thats limited as unless you know how to tune it youre heading to hawkes bay to get it tuned. Sure others will be able to tune it but as soon as you dont have a link their enthusiasm level goes thro the floor which may be reflected in the tune.
Links are bloody expensive now.
Share this post
Link to post
Yep. There are a few around that can do esl, namely stars and stripes based in hamilton.
Factory v7 on ecu can be tuned by anyone. Program is free to download, cable costs about $300 including all reflash connectors
Share this post
Link to post
one local tuner here has a love-hate relationship with links loves to hate them, hes had a couple fry circuitry and force injectors open and kill engines. fun times. his enthusiasm may jump without a link lol
Share this post
Link to post
You mean he tried to use a Link on a low-impedance injector and then was surprised when the FET injector drives failed closed?
Sounds like operator error to me.
Share this post
Link to post
Not sure, he knows his ****.
I know they were Id1000's
Share this post
Link to post
    • Steve
      Anyone going to Automania Auto festival tomorrow up at North Shore events centre?
    • Steve
      Does anyone else on here know or own one of the crouching tigers?
    • Matty t  »  gotasuby
      Help me please Hi iv fitted a dump valve to my vectra c 19 cdti 150 bhp. The 1 I bought was a twinport or receculation valve I don't no just bought and had a go of fitting it my self.  On looking at the car I thought I needed to block the 2nd port so have done bought a t and fitted it on the main intake Of The top Of The intercooler to the inlet on to Of The head.  Ran the bleed pipe and td it in to the on top Of The intake now it's just realeasing through the revs rather than when I lift of it's not because I blocked the other port is it thanks
    • WKDWRX
      https://www.instagram.com/p/BPPX4eLDujb/
    • Gordy Da Hori Hoon  »  RAYDEO
      Hi there,
      I paid online $20: for a 12 months ClubSub subscription.
      I am still waiting to receive:
      A Free ClubSub sticker A Welcome Letter & Membership Card A Discount Code for store items Can this be sorted, please.   Kind Regards,   Gordy Da Hori Hoon.     Hi Gordy Da Hori Hoon,
      Thank you for your order at ClubSUB - All We'll Drive. Your payment has been received and approved.
      — ClubSUB - All We'll Drive
        Order #86
      View Order
        Billing Address
      Gordon Samuels
      2/5 Arawa Street
      Papakura
      Auckland
      2110
        Payment Details
      Status  ✓ Approved
      Method  PayPal
      Transaction ID  3FY28950NY200842S
      Date  04/17/17 10:33 AM
      Amount  $20.00
        Order Details
       ItemTotal
      1 x 12 months$20.00
      Subtotal$20.00
      Total$20.00
