Dump pipe query BL5 legacy
im-a-bus
Hi all,
So I finally started to mod my subi, despite promising my friends/fam I'd keep it stock... :P
Having a little issue with installing the dump pipe, however.
One of the bolts connected to the turbo housing is proving to be a serious pain in the butt.... When I go to unscrew the nut, the whole bolt instead starts undoing from the turbo. I can assume that the nut is seized on? What makes this whole issue a bit more of a hassle, is I get to a certain point where the bolt just starts free spinning, so there's no way of even just removing the whole bolt. It has managed to screw back in, but obviously I need to get this sorted asap.
The car is 100% stock, so I guess it is a given that parts like this are proving to be severely difficult to remove. Anybody come across this issue before? What would you recommend to get it sorted? Is there someone who you would highly recommend to do this installation successfully?
Didn't think to take photos, so I apologise in advance!!!
