BL/BP Legacy Stereo surround / Aftermarket install?
DOHC
Literally just bought an '06 Legacy 3.0R and immediately want that factory stereo out and replaced with something bluetooth/ipod compatible. Cant seem to find any aftermarket surrounds yet i see other wagons with them installed. Anyone able to clue me in and/or have any tips and tricks for making this install easy as possible?
http://www.trademe.co.nz/motors/car-parts-accessories/subaru/accessories/auction-975835059.htm (non facelift)
http://www.trademe.co.nz/motors/car-parts-accessories/subaru/accessories/auction-975834339.htm (facelift)
expensive I know - they do pop up cheaper every now and then
You will need to check the aircon unit matches yours
Edited by ADIKT
 DOHC said:
I'm also going to assume my factory set up is worth less than dirt to re-coup some of the funds too i bet..
Of its nz new then you might be able to sell it to someone with a jdm.
But generally speaking they arnt worth a lot
 kwi_fozze said:
If its the factory kenwood unit you can get an aux in plug that goes into the back of the headunit too
Did this on mine - factory kenwood had button for 'aux' but didnt work and had no port - purchased a simple adapter off trademe and a few cables - now the button on the headunit works and have an aux port in the centre console box
 DOHC said:
http://trademe.tmcdn.co.nz/photoserver/full/415964311.jpg
This is what im working with... If that helps.
Yea so you will need this: (twin climate control) http://www.trademe.co.nz/motors/car-parts-accessories/subaru/accessories/auction-975834339.htm
Plus a headunit of your choice - you will also need a pocket to fill the gap if you go single din, an aerial adaptor to fit the new head unit if you want FM radio and wiring harnesses
That way just seems like such a compromise unless money is really tight. Hate the idea of having two stereos with one just not working. If you really want to go that route there is an upper clock cubby replacement item that fits double dinn HU's
Just save up for the lower one and get it from sobanoodle, sure its expensive but it just looks way tidier.
I wasn't a fan of that idea either... I ended up sticking mine in the glove box and having the aux in the centre console box (this was my bagged BP wagon about 6 years ago)
