Need Help Inlet mobilize Manifold Removing
subaroo
Hey guys recently I purchased a silicone induct for v5-6 due to my old one had a small crack and had to cut off nipples to remove it. Tried fitting the new one in but had no luck so last option is to take off manifold. Never removed a manifold before so don't wanna mess things up, any guide lines/ pictures/threads will help out. Thanks a lot
 boon said:
Buy new intake manifold gaskets. You will probably munt the old ones removing it.
On my V7 this was a horrible, horrible job. I would try really hard to get the intake pipe on without removing the manifold if it was me.
hmm ill give it another try tomorrow. Taking off the manifold seems like a pretty easy job, just few bolts on each side of the manifold but kinda confused on the fuel lines/injectors.
(might need to move the alternator to get to all the bolts?)
Lifting the inlet mani makes things so much easier, just undoing the 8 bolts securing it to the block alone gives maybe an inch of leeway - and as my ex said another inch would make ALL THE DIFFERENCE MARK
Lel
Lel
This, don't need to remove alternator bolts from memory, when I did mine I just un bolted the mani and lifted it up gives you just enough room to shove the ****er in there. Still a ***** of a job though, grazed more than a few knuckles shoving it in there and getting all the pcv lines, bov recirculation etc back on the silicone one with the manifold on there is no fun either Would definetely reccomend just removing the mani, unbolt, undo fuel lines, unplug harness and remove pcv lines etc then should just pull up... if my memory serves me correctly.
